The slow road back
Discussion in 'The Wood Pile' started by EODMSgt, Nov 16, 2025.
  1. buZZsaw BRAD
    The FHC spirit is alive and well in you!!! :salute: I love it!
  2. Horkn
    There's still so much dead ash here that I can process it and it will be ready for the next year no issues. Now when I get longer to season wood, then I process it and usually let it sit outside for 9 months to a year before getting it in the shed.
  3. brenndatomu
    Sounds like something else to me...like a carb passage that is still not fully open, or something along those lines.
    I had a carb on a Honda GX340 that really fought me here a month or two back...I had the dumb thing apart 5-6 times until it stopped surging (unless the choke was left partially on) but I finally won!
  4. Horkn
    It's odd because after I reinstalled the carb in Spring, it started up and ran just fine. It was funky until warmed up, because the choke is the linkage that is wonky. When trying to start it a week or so ago, it would pop over when primed, then crap out and even though the muffler got hot, it never washed to actually run more than the brief time. Pushing the primer I couldn't ever get it to catch and stay running. I pulled it over like 80-100 times. The carb was fully cleaned in a vibra tank. Parts cleaner.
  5. EODMSgt
    EODMSgt
    White Mountain Region, NH
    Beautiful morning so did an early tree drop of that oak that I wanted down before I really start working in the woodlot. Kind of an unorthodox hinge, however the curve of the trunk and all the limbs wanted to pull the tree 90-degrees from where I wanted it to go (everything was going towards the large boulder to the right of the tree in the picture, and yes, I moved the tractor before I dropped the tree). I did the face cut, then started a back cut on the side the tree wanted to lean (I'll call it the front side), pounded in a wedge, started the back cut on the opposite side, trimmed a bit more on the front side and added another wedge, then just finished the back cut from the back side knowing I wasn't leaving much of a hinge. I was pretty much relying on the wedges to guide the tree. Worked like a charm and the tree dropped right where I wanted it (which couldn't be better because it's right at the back of my existing log pile). Don't know if it was skill or luck, but I'll take it and call it a win in the books.
    20261014_155103 2.jpg 20261018_104123 2.jpg 20261018_104152 2.jpg 20261018_104528 2.jpg
  6. Canadian border VT
    Great pics EODMSgt beautiful weather we’re having. I will have some victims too. Yellow birch
  7. MikeInMa
    Good job!! Always nice to see them horizontal.
  8. buZZsaw BRAD
    Good job getting it on the ground safely. Always a plus when a plan goes the way you wanted it! And it was all skill on your part!!! :salute:
    Horkn, Backwoods Savage, RCBS and 8 others like this.
  9. Horkn
    Yesterday I took the splitter over by my buddy's. Yep. Clogged jet. Why? Idk. But it was. It runs great after cleaning it out. There's a filter on the line and that was new in Spring.
    Hauled a load of mostly ash home yesterday. Can't load, when a screenshot of a screenshot. Grrr
    Then I ran a tank and a half through the splitter.
    And a screenshot of that trailer load of splits is still too big. So , you'll have to trust me on that
  10. Horkn
    Ok, a screenshot of a screenshot worked. This is the load I split that I need to stack Screenshot_20261026-090349.png
  11. EODMSgt
    EODMSgt
    Too windy today to finish the shed so worked on a couple other of the never-ending projects to be done before winter. I needed to consolidate some of the logs in the woodlot and that gave me partial access to the oak I had dropped a couple weeks ago. Started bucking the limb wood and then figured I would winch the tree out, section it, and add it to the log pile. Was having too much fun (with the tractor and the chainsaw) and hadn't really run a saw in a while (other than dropping the tree) so used the grapple instead, pulled the tree up a little at a time, and bucked it with the 261. Nice little stack of RO to be split when it was all said and done (and the supervisor approves - last pic).
    20261030_120240 2.jpg 20261030_141514 2.jpg 20261030_141529 2.jpg 20261030_142120 2.jpg 20261030_142910 2.jpg 20261030_143638 2.jpg 20261030_144438 2.jpg 20261030_152940 2.jpg 20261030_154116 2.jpg
    Chud, RCBS, MNWood and 15 others like this.
  12. Horkn
    I took today off from work to make this a long weekend. So today stacked the trailer of wood that I posted the picture of previously.
    I then ran the dolkita and shortened the few rounds that were just a bit too long and split up and loaded another trailer full of splits. A lot of pine, with some ash, basswood, box elder, and a few rounds of poplar. I'll get a little more done tomorrow as well, probably early.
  13. The Wood Wolverine
    Living vicariously through this post, thanks for sharing. I need some saw time soon!
  14. Canadian border VT
    Yes the tractors nice, and the grapple is cool; as is the new splitter BUT that supervisor is great looking
    Horkn, eatonpcat, metalcuttr and 5 others like this.
  15. metalcuttr
    metalcuttr
    western WA
    "Don't quit on me now!"
  16. EODMSgt
    EODMSgt
    A little splitter and saw time today to (finally) start chipping away at the log pile. Two trailer loads isn't much, but it's something. Of course, the supervisor had to check out the uglies bin.
    20261118_100804 2.jpg 20261118_110557 2.jpg 20261118_142810 2.jpg 20261118_122250 2.jpg
    sms4life, Woodwidow, Horkn and 12 others like this.
  17. MikeInMa
    Slow and steady wins the race.
    Nice looking splits
  18. Eric Wanderweg
    I really like that double axle trailer with the winch. Very solid setup. Did you just get your driveway regraded too?
  19. metalcuttr
    metalcuttr
    western WA
  20. brenndatomu
    X2.
    I seen one like that on FBMP for $800 earlier this summer, I messaged that I'll take it, when can I pick up?
    Nothing...marked sold a couple hours later...rats!
