Road rebuild
Discussion in 'Everything Else (off topic)' started by MikeInMa, Apr 11, 2026.
  1. MikeInMa
    Perhaps, "that'll do".... for now.
    I had the same thought. They do mix up concrete as they go.
    That's pretty much where the stone wall was located.
  2. brenndatomu
    You are correct...10 years from now (or less) you'd be able to grab that casting and walk off with it...I see it all the time.
    If the guy attempted to "do better", then there is a ring or two of Con-Seal under there...not so much because that drain grate needs sealed (but that would be important on a sanitary manhole casting) but more to help "glue" it down.
  3. buZZsaw BRAD
    Id have to agree. Looks like extra concrete mix. Thinking the road bed of crushed stone will be level with the top and asphalt put over it. Just a guess on my part.
  4. RCBS
    I don't see them unstacking that to mortar the joints. Understand that material will be compacted around...seems jointing the blocks would be more durable...but what do I know...I am not a drainage engineer by any means (or a brickie). lol
  5. MikeInMa
    Here's the see-ment truck they use
  6. RCBS
    NGL...that's pretty slick.
  7. buZZsaw BRAD
    Calling jo191145 He's the see ment expert here.
    I see sand so they are making there own mix whether mortar or concrete.
    RCBS, T.Jeff Veal and brenndatomu like this.
  8. eatonpcat
    Agree
    RCBS, T.Jeff Veal, MikeInMa and 2 others like this.
  9. MikeInMa
    No real activity in front of us lately.
    There's still digging and trenching just east of us, continuing with drainage efforts.
    You can see our flag and toolshed in the distance over the line of sight across the pipes
  10. MikeInMa
    Well, our turn to be inconvenienced again.
    Drainage going in, including across the driveway. Should be OK in an hour. We have errands to run.
    Cutting the driveway with a saw, see.
    Thin bucket for a trench
  11. buZZsaw BRAD
  12. huskihl
    huskihl
    No, I have not
  13. brenndatomu
    Aww, comeon...not even your own?!
  14. huskihl
    huskihl
    Nope. Most of them have 10k rpm limited coils. Porting would make them hammer on the limiter nonstop
  15. RCBS
    I've seen video of a string trimmer done up. Never yet seen hedge trimmers or backpack blowers.
