Fall Time Hoarding
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Sep 23, 2026.
  1. buZZsaw BRAD
    Time for a new thread since Summer is over.
    Cut my first truckload of the season yesterday. Honey hole I've cut from and low on the priority scale to get back there. Load of mostly elm and cottonwood with some dead Norway maple topping it off. I split most of it today save for a few elm rounds as I ran out of patience as some were rather stringy. Bark had loosened on most of the elm. Some for bundle inventory, some general cordage, some dead wood and a bit for pit wood.
    Older pic (mid May) when I first cut there. They added more logs June/July. Probably 3-4 more loads to cut here. I may cut another load before the Noreaster hits as mud will hinder access since I have to back up a hill on a new construction lot. [​IMG]
  2. MikeInMa
    Look at you! Posting pictures again! :handshake:
    Did you have help?
  3. buZZsaw BRAD
    Older picture that I copy pasted from an earlier thread. Pic is from May before forum had the problem with photos.
    brenndatomu, Heptameron, Chaz and 9 others like this.
  4. RCBS
    I can participate in this one! Not yet though. Soon. Gotta get up on shed roof this weekend among other non wood making junk needing done.
    brenndatomu, Heptameron, Chaz and 8 others like this.
  5. rainking63
    rainking63
    Old Lyme, CT
    Looking good!
    brenndatomu, Heptameron, Chaz and 5 others like this.
  6. T.Jeff Veal
    Way to go, my friend.
    brenndatomu, Heptameron, Chaz and 3 others like this.
  7. Horkn
    Ah yes, it's that time again. I ran a tank of fresh fuel through my dolkita last weekend. I cut up the pine and ash that I collected over summer. About a face cord. Now I gotta get the splitter running. Stupid linkage that I never got right in the Tecumseh after getting the carb rebuilt. It pulls over, runs briefly on primer. It's just the choke / governor that needs to be hooked up right.
  8. Canadian border VT
  9. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Looking good Brad. No new wood here, haven't even talked to my tree fairy lately. Need to fire up the splitter soon as well and clean up the mess in my yard.
  10. The Wood Wolverine
    Hoping to join you on some fall firewood work soon. Dad’s friend is wanting some more trees removed. Fingers crossed I can get some trigger time. I’m itching to run the oe372 Eric sent me.
  11. buZZsaw BRAD
    Hit the same score again later yesterday. I wanted to beat the rain incoming from the Noreaster. 50/50 mix of cottonwood and Norway maple. Half cord load. Hoping for a lull tomorrow so I can split some or at least unload it.
    Still MOTS at the score. Probably will leave most of the wood in the OP pic as its been there since Spring and is sitting on grade...muddy and loose cottonwood bark...yuck. Still a couple decent loads from the logs that were added. Problem is they are in back of the pile and some work to get them out. Some scores are more work than others. Well it is what it is.
    May check out a local FBM find tomorrow. Hickory from the looks of it. Have a cut at another honey hole next week. Dead sugar maple take down.
  12. buZZsaw BRAD
    Cooler temps are here. Sure beats sweating.
    Hoard on and cut safe.
  13. MeanJoe
    MeanJoe
    Western Michigan
    Sure is nice to cut wood in a long sleeve shirt and not get too hot. If only the chaps had a built in fan…
  14. Eric Wanderweg
    I mean… there’s no rule saying you have to wear pants under your chainsaw chaps :whistle: :rofl: :lol:
    That’s my biggest gripe about wearing them too. You get overheated fast in the warmer weather with them on.
  15. buZZsaw BRAD
    I tried them once. Too clumsy for me. Seems id be more likely to cut myself with them on.
  16. Eric Wanderweg
    I’m no Mr. Safety myself when it comes down to putting them on. If it’s a big job with a lot of cutting then usually I’ll wear them. For half a dozen rounds I don’t bother. I always carry a tourniquet with me as a backup… :confused:
  17. buZZsaw BRAD
    Work boots, long pants, and hearing protection SOP for me. I do have the helmet with face shield and hearing protection ive worn at my Disney cut. Does get uncomfortable after a while. Ill usually wear it when felling too.
    No touniquit, wads of napkins usually work for "bad" wounds IME:emb:
  18. MeanJoe
    MeanJoe
    Western Michigan
    I’m 50/50 on if I like chaps or not but I wear them. It does keep the chips off the clothes so I don’t have to clean the washing machine out. Otherwise yes, a bit uncomfortable and hot!
  19. Skier76
    Skier76
    CT and SoVT
    I can tell what part of CT that is just based on the soil color!
  20. RCBS
    I had my 'opener' yesterday. Got 3-4 more HL stems to get yet. Then I'll start in on the big Bitternut. Cool and breezy but the sweat was flowing pretty good.
