how hot do you neep your wood stove
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by chain saw guy, Sep 10, 2026.
  1. chain saw guy
    chain saw guy
    pa
    I wss told to keep my wood stove to 1000 deg or more i dont get cresote build up in the chimney
    brenndatomu, MikeInMa and wildwest like this.
  2. Jeffrey Svoboda
    Jeffrey Svoboda
    Wow! :bug:I wouldn't do it regularly.
  3. wildwest
    The way to prevent creosote is by not burning green wood, it must be seasoned/dry. Low and slow has advantages and drawbacks but as you begin to burn you'll know what you need and 1000* isnt worth imo.
    Did you read the link Backwoods Savage sent you on the other thread "3 year plan"?
  4. MikeInMa
    Our woodstove probe thermometer (down to the cat) reads ~800⁰ in the middle of winter.
    Creosote gets created mostly by burning wood that's not dry enough.
    1,000⁰ sounds excessive.
    Primer on Woodburning by Backwoods Savage
  5. Canadian border VT
    Every stove thermostat I’ve seen would be redlined at 1,000°
  6. Canadian border VT
    I in 20° below or less keep my stove top temperature between 600° and 700°
  7. RCBS
    Dunno the temp in the firebox. My thermo is on the pipe and I like it to read 300-400.
  8. Backwoods Savage
    That is flue temp which is different from stove temp.
  9. Barcroftb
    Barcroftb
    The Mitten
    Danger picking nits ahead. You’ve been warned.
    Yes it’s true that a green wood fire will produce creosote but burning any wood creates creosote, or rather, the products of combustion that become creosote under the right conditions.
    The difference is that a greenwood fire never gets hot enough to raise the flue/chimney temperatures high enough that the condensation and products of combustion exit the chimney before they condense causing the dangerous creosote build up in the chimney. Having said all that 1000 degrees stove top is too hot for most stoves. What stove you running chain saw guy and where are you measuring your temps?
  10. brenndatomu
    What are you burning in?
    It depends where and how you are measuring that...if it's the stovepipe, then an external surface mag thermometer will read about 1/2 of the actual internal temp...so 3-400* there is fine.
    If measuring the top of a basic steel stove then 800* should be considered about the high limit.
    A stone stove, or a cat stove, well it just depends what it is, and how you are measuring it.
    My wood furnace has a thermocouple in the top of the combustion chamber and 1000-1300* is the normal operating range for that.
  11. wood and coal burner
    Quakertown,PA
    The griddle will normally be 600 but sometimes it will hit 800 or even 850 and that is high but I am burning a Vermont Castings Vigilant II which was designed for coal so it can take it. I would not like to push a non cast iron stove or any stove to 1000.
  12. The Wood Wolverine
    Nvr mind, I googled it..
    :zip:
    buZZsaw BRAD and brenndatomu like this.
  13. brenndatomu
    :binoculars:
  14. Burnin Since 1991
    Burnin Since 1991
    just wondering what kind of a stove you have?
    where on your stove are you measuring 1000 degrees and what you are using to measure that?
    brenndatomu and buZZsaw BRAD like this.
  15. yooperdave
    chain saw guy
    There's a lot of members here that would like to help and offer their advice for burning practices.
    Please check in and reply. :handshake:
  16. WeldrDave
    WAY excessive!
    What she said!!!
    I NEVER exceed 500º on my flue pipe temp! As a matter of fact, I like to keep it between 350º and 400º and I'm burning an old Fisher. My thermometor on the stove top stays at 400º to 425º and I get plenty of heat!
    Getcha a magnetic Burn indicator thermometor.
    https://www.amazon.com/s?k=rutland+...e0&tag=googhydr-20&ref=pd_sl_1idjb48dim_e_p67
    MikeInMa, brenndatomu and wildwest like this.
  17. wildwest
    He revealed himself as a troll not too long after this post.
