is it ok to burn some pine wood
Discussion in 'The Wood Pile' started by chain saw guy, Sep 9, 2026.
  1. chain saw guy
    chain saw guy
    pa
    is it ok to burn some pine wood in fireplace and wood stove
  2. ole
    ole
    Rock County Wisconsin
    Yes. Just make sure it’s dry just like hardwood.
  3. Eric Wanderweg
    Pine, spruce, hemlock, tamarack, fir... it'll all work so long as it's dry. The only real downside besides dealing with the knots is that you'll be reloading more often.
    Horkn, T.Jeff Veal, tamarack and 11 others like this.
  4. chain saw guy
    chain saw guy
    pa
    only have abought 8 split logs of pine wood
    Horkn, eatonpcat, metalcuttr and 5 others like this.
  5. brenndatomu
    Cut it, split it, stack it, burn it!
    Rinse, repeat.
    :saw: :stack::axe::stacker:
    :thumbs:
  6. Chud
    Chud
    It’s all fun and games until you’re calling 911. Just kidding, I like having some dry pine for quick fire ups.
    Horkn, T.Jeff Veal, eatonpcat and 8 others like this.
  7. Ctwoodtick
    Ctwoodtick
    Southeast ct
    Pine is fine. I have 2.5 cords of it ready to go for this season. Have burned it plenty before and no issues in chimney. I’m the one that sweeps it so I know.
  8. Scotty Overkill
    Nothing wrong with seasoned pine or spruce. I will say it burns hot and fast if it's getting lots of air when burning, so experiment with it to learn it's characteristics with your specific appliance. In a tight stove, it will surprise you how good it will last and heat. Many northern woodburners use nothing but spruce and tamarack all winter long in some cases. We've had members that live in Alaska using Blaze King stoves getting 12-16hr burns from loads of spruce IIRC.
    Horkn, Rope, T.Jeff Veal and 11 others like this.
  9. buZZsaw BRAD
    Yes. Be sure its dry.
    The best firewood is dry firewood.
  10. The Wood Wolverine
    Pine is fine.. as long as it’s dry. :coldfire:
  11. brenndatomu
    That's just it right there, pine (conifer wood) gets a bad rap because it will burn wet (sap/pitch burns good!) so some people do, and that's what causes the problems...
  12. Backwoods Savage
    Pay attention to all the posts about the pine being dry. Of course that does not mean dry to the touch, it means low moisture inside the log or split. Split a few, even though there were probably split already and check to make sure it is dry. Typically wood sellers cut the tree, buck it up and then split. Next thing is to just sell it. They do not have the time nor do they want, to dry the wood before it is sold. That is why one needs to stack it where it can get good circulation and most times some good sun helps much. Cover the top of the stack but not the sides so the wood gets air.
    I hope this helps. This may also help: Primer on Woodburning by Backwoods Savage | Firewood Hoarders Club
  13. jo191145
    IMO the biggest problem with pine is what you burned before it. Too many people burning green hardwood low and slow making tons of stage 3 creosote in the chimney. One year they run out of green wood, find some dry pine and toss that in the stove. Hot and fast doesn’t mix well with a chimney saturated in creosote. That’s how you burn down a house.
    It’s not the pines fault. It’s the bad habits before the pine that come home to roost.
  14. Heptameron
    Heptameron
    Spain
    Absolutely no problem.
  15. wildwest
    Colorado and Wyoming burn lodgepole pine almost exclusively.
  16. stuckinthemuck
    stuckinthemuck
    I have nothing to add other than we heated for a whole winter in NH only burning pine because we had so much and I wanted to get rid of it. We did just fine. All good advice above.
  17. buZZsaw BRAD
    Ive explained the same thing more or less to a lot of folks who look at me like I have two heads when I tell them.
    Horkn, jrider, T.Jeff Veal and 9 others like this.
  18. jo191145
    well it doesn’t help that you have two heads LOL
  19. buZZsaw BRAD
    :emb: :rofl: :lol:
  20. brenndatomu
    Absolutely true.
    Horkn, metalcuttr, Chaz and 4 others like this.
