Water get into the support box
Discussion in 'Everything Else (off topic)' started by timusp40, Jul 3, 2026.
  1. timusp40
    timusp40
    Lake Orion, Michigan
    My setup was installed in 2013. Chimney is triple wall Duravent. Stove pipe is double wall from same mfg. I purchased the entire package from the cap to the stove at the same time making sure that nothing is mixed or mismatched.
    All has been fine until lase season when I noticed water drops coming from the support box. Obviously, I have a leak somewhere. I have been on the roof, checked all on the sealed areas, looked for cracked or loose shingles etc. Even had a neighbor up there while a sprayed water everywhere but can't find the leak.
    Any time it rains more than a little, I'm getting the dripping from the support box.
    Got any ideas? Im about to call a professional roofer out but thought someone out there might have had a similar problem DSCF3787.JPG DSCF3780.JPG DSCF3780.JPG .
  2. buZZsaw BRAD
    Did you check the seal on the storm collar? Rain would have to drive in the right direction if the seal has a small crack.
    Am I seeing fresh caulk/silicone in the pics?
  3. buzz-saw
    buzz-saw
    Ct.
    X2. Check the seal ,around the collar to the pipe. Had same thing here.
  4. Backwoods Savage
  5. timusp40
    timusp40
    I'll have the seal on the storm collar checked. I don't go up on the roof myself anymore. Those days are behind me.
