Mini skid
Discussion in 'Chainsaws and Power Equipment' started by Ohio dave, Jun 25, 2026.
  1. Ohio dave
    Ohio dave
    Akron, OH
    Any opinions on a mini skid. I would use it to snow plow 500ft of our gravel road, double stack IBC totes, and move rounds and splits around.
  2. jmb6420
    jmb6420
    Grand lake, Oklahoma
    Just make sure the lift capacity can handle the loads you want to move around. You don't want to stand it on it's nose with you in it.
    My name is Mike, and I'm a hoarder in Ok.
    Lopi Endeavor and Republic 1250
  3. Chud
    Chud
    I have used a Toro Dingo and a Vermeer. They can do an amazing amount of work, but it would take a big machine to lift a tote filled with wood. IMO once you get into the price of big minis why not just get a used traditional skid steer.
  4. Ohio dave
    Ohio dave
    Akron, OH
    That's why I was asking.
    T.Jeff Veal, Chud, jmb6420 and 2 others like this.
  5. brenndatomu
    I don't think a Mini skid is picking a loaded IBC tote.
    Barcroftb has a Dingo IIRC...
    Barcroftb, T.Jeff Veal, Chud and 2 others like this.
  6. Canadian border VT
    I couldn’t remember if it was you or barcroft
  7. eatonpcat
    I think Brad Barcroftb sold that Dingo when he bought the tractor, but I could be mistaken
  8. morningwood
    morningwood Administrator
    My tractor has lift capacity of a ton, and it's pretty tippy (rear tires are loaded with beet juice) without something on the back when picking up a 330 gallon tote of dry wood, let alone green wood. I'd recommend a full size skid loader or a 4 series (40HP+) tractor to safely move them around. Yes, a newer 30HP tractor will move them around but it's probably not the best thing for the front end.
    Chaz, Chvymn99, eatonpcat and 4 others like this.
  9. brenndatomu
    Nah...it'll be fine...just ask T.Jeff Veal, they make new wheel bearings everyday! :whistle: ;) :tractor:
    Chaz, Chvymn99, morningwood and 6 others like this.
  10. Butcher
    Butcher
  11. cezar
    cezar
    KY
    Cheap old Ford tractor with forks on the back will get you 3,000lb capacity under 10k out the door. Just a thought.
    Chaz, jmb6420, brenndatomu and 3 others like this.
  12. Barcroftb
    Barcroftb
    The Mitten
    Ohio dave I missed what your budget was? All of the large body units from Ditch witch/toro, Kubota, Vermeer, etc. will pick around ton. Ditch witch/toro has a large unit that will pick 3000#s. Those machines are all spendy.
    There are some good quality Chinese minis from Derette, and Rippa that will also pick over a ton. Which is enough to pick an ibc tote. Heck I used to move half full totes with my little wheeled 320 dingo. Used to plow a 600 foot driveway with it too. I’d upload pics but well we all know how that’s been lately. Tip load on that 320 was around 1,000.
    As someone with experience running a mini daily for several years I would say a mini excels at precision material handling. They are great for tight residential work with attachments like a grapple, bucket, plow, stump grinder, or brush mower. They are terrific for tree work and I’d much rather have one than a tractor. Having said all that, I wouldn’t want to use a mini to move ibc totes as its primary activity. They are kind of slow compared to a full size skid loader or tractor. A mini’s top speed is going to be in the 5mph range. Not much of an issue if your property is smaller. If your property is large I’d go full size skid loaders. If you’re handy there is always a lot of used full size skid loaders on the used market with a lot of life left in them.
  13. Ohio dave
    Ohio dave
    Akron, OH
    It's not really a budget issue is more of a issue of space. My yard isn't big and storage is even less
  14. Barcroftb
    Barcroftb
    The Mitten
    Mini sounds like a good use case for a small yard. I bet you’d be pretty happy with one for general property maintenance and firewooding.
    Chaz, Chvymn99, morningwood and 2 others like this.
  15. morningwood
    Any reports on how these Chinese machines last long term? Was poking around the Rippa USA web site, and they wanted $30k for a 25HP excavator, which is roughly half of MSRP for what a new Kubota excavator for the same size would be.
  16. jmb6420
    jmb6420
    The problem most people have with them is getting service and repair parts for them. They are "fine " until you need parts.
  17. Barcroftb
    Barcroftb
    The Mitten
    Not sure they’ve been around long enough to say how they hold up long term. There are a couple good big dealers for the Chinese excavators/skid steers. One in Texas (Rippa USA) and one in Ohio (gsa equipment). I’m sure there are others but those are two of the big ones. GSA Equipment in Ohio seems to carry a lot of them and keep parts in stock. At this point they are popular enough that I can’t see the more established companies like Derette and Rippa going away anytime soon.
  18. brenndatomu
    From what I've been reading, long term quality has been poor on most of them, some brands are a little better than others, some are bad right outta the chute, but overall it seems the ole rule about "you get what you pay for" applies with any of this "cheap" chinese equipment.
    jmb6420, eatonpcat and morningwood like this.
  19. morningwood
    I've heard the same thing. If you are homeowner, and have the need for this type of equipment, are going to keep the equipment long term, and have the ability to work on equipment, I think it might be a good route to take. I say keeping it long term because I'm sure the resale value is not that good. Personally, I'd opt for a low hour used machine from an established brand, JMHO of course.
  20. lukem
    For the uses you describe a mini skid would be near the bottom of the list of options for me personally. Operator fatigue on those is a real thing. Every time I've used one of those or a concrete buggy my lower back was pizzed. Plowing 500ft of driveway with one sounds miserable. They are nice for getting through a gate or in other tight spaces, but I would much rather have an operator station with a seat and some real power under me.
    We all have to work within a budget, but I'd keep exploring your options for a tractor or full size skid loader.
