Leaking Oil - cracked case
Discussion in 'Chainsaws and Power Equipment' started by CoachSchaller, Jun 13, 2026.
  1. CoachSchaller
    CoachSchaller
    Southeast Michigan
    Had a branch come back and hit me in the leg. I'm fine, because the case took the brunt of it. The case cracked next to the bar and now has a bar oil leak. Anybody got a good fix for this?
  2. Ronaldo
    Ronaldo
    Bummer to have a repair like that, but it is probably better than a good crack on the leg! I had a branch get me hard on my shin and I think it bruised the bone. It took months for it to heal and swelling and “color” to go away.
  3. CoachSchaller
    CoachSchaller
    Southeast Michigan
    Is JB weld good to use on this cracked case? I also have two part marine epoxy...
  4. ammoaddict
    ammoaddict
    Granite Falls, NC
    What saw? Magnesium case or plastic?
    metalcuttr and isaaccarlson like this.
  5. Locust Post
    If I was going to try anything it would be 2 part epoxy
  6. Mrxlh
    Mrxlh
    Dat Boot
    It can be welded, SCarr has fixed more cases that should have been thrown in a dumpster than Carter has liver pills… JB weld or the 2 part should be fine, but it must be clean, clean…
  7. isaaccarlson
    isaaccarlson
    Colfax, WI
    If you have access to a welder who is good, go that route. Otherwise clean the heck out of it and use jb weld. Work the jb into the surface with a toothpick. It makes it stick better. And sand it to bare metal first. It’ll hold. That saw probably saved you a broke leg!
    metalcuttr, eatonpcat and Mrxlh like this.
  8. CoachSchaller
    CoachSchaller
    Southeast Michigan
    cast. So I am guessing magnesium definitely NOT plastic. Stihl 441
    metalcuttr and eatonpcat like this.
  9. CoachSchaller
    CoachSchaller
    Southeast Michigan
    I agree. It still hit me and hurt, but that is just par for the course.
