Finally getting some red oak splits back home
Discussion in 'The Wood Pile' started by Michigander, May 18, 2026.
  1. Michigander
    Michigander
    Macomb Michigan
    I cut this red oak back in Jan '25. It was a blow over that looks like it had some carpenter ants in the bottom. Rest of the tree was all solid. I hand split some and had it piled up. Had to wait for after the winter when I had more storage space at the house. It is very muddy out at my friend Bob's property. Had to make two trips with his tractor to get the wood out. I still have another 2-3 truckloads to move. 24" bar on my Echo 590.
  2. Michigander
    Michigander
    Macomb Michigan
  3. Boogeyman
    Boogeyman
    Central Indiana
    Great looking truck!! Is that a Cummins sticker I see up front?
  4. Michigander
    Michigander
    Macomb Michigan
    Thanks! It is a 1997 F350, last year for this body style. I have owned it since 2013. I cummins swapped it in 2017.
  5. buZZsaw BRAD
    Nice you are finally getting it out of there. I've encountered oak like that. Messy yes, but easier on the back when loading! Easier to chunk down.
    Sweet truck too. Love me a hard working, wood haulin' Ford. Been driving F150's since 1988.
  6. Michigander
    Michigander
    Macomb Michigan
    Brad, you got me beat. I had a 1986 f150 in 1990-1992. 4x2, 300-6 carb. 4 speed. It ran well but wasn't fun in Michigan winters. I swear we got more snow back then.
    I was surprised how dry some of those oak splits were. They didn't get much sun but have been sitting on top of that pile for 16 months. I will try to get the rest home soon. I'll split and stack it all together. Hopefully it will be ready for winter of 27/28.
  7. T.Jeff Veal
    Nice red oak and beautiful truck.
    Well done, sir. Yes that oak should be dry enough by then
  8. Backwoods Savage
    There is a lot of wood in that one tree!
  9. Michigander
    Michigander
    Macomb Michigan
    I'm guessing it is close to a full cord. Thanks for the kind words everyone.
  10. Michigander
    Michigander
    Macomb Michigan
    Long overdue update. This picture was taken May 20th. It is 16' long, roughly a 1/2 cord.
  11. Michigander
    Michigander
    Macomb Michigan
    I finally went back to get the rest. This is the same red oak that was piled on the ground for almost two years. It is all still very solid. I had to noodle some of the big rounds, that can be seen from the picture at the beginning of this thread. The rest I could easily hand split, so it was light enough to load in my truck. Bark was falling off and it was all much lighter. I have never left wood this long, especially on the ground. It is in a spot that is muddy and hard to access most of the year. I put some pallets down and stacked it behind the rest since I don't have any empty racks.
  12. buZZsaw BRAD
    Sweet stacks in post #10.
    Ive faced similar dilemmas (including part of my woodyard) with mud and inaccessibility. One benefit of oak is the resistance to rot of the heartwood just as long as you don't mind the dirty rounds. Plus its ease of hand splitting.
  13. Michigander
    Michigander
    Macomb Michigan
    Thank you. As can be seen in the last picture, that row is now top covered. I'm going to try and cover the rest with some plywood scraps. Weather has been perfect for working. 50-60* and dry.
  14. buZZsaw BRAD
    If the DBH (Diameter at Breast Height or 4.5' high) is 22" the tree will yield a cord of wood if you harvest down to 4". 16" DBH will yield a half cord, 13" a face cord. There are variables, but a good general rule of thumb.
  15. Michigander
    Michigander
    Macomb Michigan
    Great info. I didn't measure this tree, because it was already on the ground. But it was close to 24". Nice size branches too. A cord sounds right. I love how most of it is bark less now from sitting so long.
  16. NC-PersimmonDude
    NC-PersimmonDude
    Mega useful "back of the napkin" estimation tip there!! Best of all, it matches what seems to happen in the real woodlot. True FHC practicality here.
    " The only time the world makes sense to me is when I am splittin' firewood."
  17. T.Jeff Veal
  18. buZZsaw BRAD
    I have myself have stacked wood harvested from trees that size and it is accurate. Not much of my wood is scrounged from full though.
    Here's the reference I found online years back when I first joined FHC.
    Estimating Firewood from Standing Trees - class.ucanr.edu
