What do you clean your saw with?
Discussion in 'Chainsaws and Power Equipment' started by MeanJoe, May 4, 2026.
  1. MeanJoe
    MeanJoe
    Western Michigan
    I became the babysitter of 3 80’s Echos, in addition to the 302 I need to fix. 500, 610, and a 750. All run and look pretty decent. I doubt I’ll use them as main saws to try to preserve them, but fun to run sometimes. I’d like to keep them clean. What does everyone use to wipe their saws down that doesn’t thin the paint over time?
  2. RCBS
    Finish safe brake clean, air gun, rag and silicone spray.
  3. Eggshooterist
    Eggshooterist
    Erff
    I use either mineral spirits or a water diluted degreaser called super clean. I use an air powered siphon wand to apply the cleaners / blast away grease and grime. I take precautions to keep the cleaners out of the exhaust and intake. Once cleaned and dry, I apply a product called mudslinger from amsoil.
  4. MeanJoe
    MeanJoe
    Western Michigan
    I thought about mineral spirits but I didn’t know if that would start to soften the paint on those old saws. I know when I wipe up the couple drops of spilled mix gas there’s an orange tint on my rag.
  5. Eggshooterist
    Eggshooterist
    Erff
    I haven't noticed that issue with mineral spirits but have with that suoer clean if not diluted enough or left on to long. Most of my saws are early 70's - 80's
  6. MeanJoe
    MeanJoe
    Western Michigan
    Thank you! I’ll try it on the inside of the clutch cover first to see if it starts to wipe paint off. I’m think at one point someone told me about a degreaser made for aircraft that was extremely finish safe, yet cleaned grease off quick. I’ll have to try to remember what it is. I’m sure it’s expensive.
  7. buzz-saw
    buzz-saw
    Ct.
    An air-hose , that's it.
    Treat it like a fine suit jacket. Dry clean only.
  8. Eggshooterist
    Eggshooterist
    Erff
    Slacker...
  9. WeldrDave
    First I blow as much crud and sawdust off with the air compressor, then I generally use (Spray 9) or a cleaner as such and give them a good wipe down. I've neglected to do this, this past few times I used my saws. :whistle::emb:. I was A$$ whooooped the last few times and just parked them on the shelf. :picard: I also flip the bars after every other use for even wear.
  10. lukem
    I keep a spray bottle of diluted super clean in the shop...just give it a good going over then hose off within a minute or two. Works on everything.
  11. Eggshooterist
    Eggshooterist
    Erff
    Its good stuff for sure.
  12. brenndatomu
    Same here normally...maybe a little soak of WD-40 if there is greasy bar oil buildup that needs help.
    I did try to wash the MS261 at work with creek water some weeks back...the tree I was cutting on the bank went in an unexpected direction, I just took off...saw went for a swim, fortunately it was just the bar and muffler under (intake was still dry) and not for long, I let it drip dry for just a bit, and it was back to work, no issues.
  13. lukem
    Not to be confused with Purple Power...that stuff is not as good.
  14. Eggshooterist
    Eggshooterist
    Erff
    I've never used purple power. Just the super clean... thats purple... in the purple jug. lol
  15. The Wood Wolverine
    Compressed air for me, that’s all it takes.
    MeanJoe, T.Jeff Veal, Erik B and 2 others like this.
  16. isaaccarlson
    isaaccarlson
    Colfax, WI
    Mine go for a swim in the sink with soap and water. Only when porting…
    I like to blow them out with compressed air after removing the recoil.
  17. MeanJoe
    MeanJoe
    Western Michigan
    I’ll blow them out and wipe them with a watered down degreaser when I think they’ll sit for a while. I didn’t intend on using them much but here I am on EBay looking for parts saws and the other models in the EVL line…
    WeldrDave, eatonpcat and brenndatomu like this.
  18. walt
    walt
    north central ohio
    Lemon Pledge and a miro - fiber cloth, won't hurt the plastic or the paint.
  19. MeanJoe
    MeanJoe
    Western Michigan
    I’ll try this. Never thought of Pledge.
