John Deere GS45 Deck Repair Advice
Discussion in 'Chainsaws and Power Equipment' started by Skier76, Apr 30, 2026.
  1. Skier76
    Skier76
    CT and SoVT
    Quick background: I’ve had this mower for 10-12 years now? It’s been a homeowner unit since new. Bought it off a friend who had maybe 1/4 of an acre of grass to mow. Since I’ve had it, It’s mowed our lawn which is on one acre, but obviously not 100% of that is grass.
    I’m getting some bubbling paint unfortunately. Over the last few years, I’ve been doing my best to clean the deck after every mow; especially in the spring when the grass is more moist. After my spring tuneup, I looked at the deck and saw some of the metal starting to flake under it. Ugh! This mower runs mint and only has about 450/470hours on it.
    Did a little research with AI; make/model, problem with it, pics and tools I had. Here’s the solution it came up with: Hit the underside of the deck with a needle scaler and a flap disk. Then, a rust converter and some paint. From there, fluidflim it regularly. For the top, scuff it up, hit with some paint using an HVLP gun I have better never used. Would be good practice as it’s a mower deck.
    I wanted to ask here because I know there’s some good experience. I welcome any advice. Some pics for reference.
  2. Canadian border VT
    Ok we did this once at dads camp, basically advice is same for preventing rust on underside of vehicles.
    Take deck off turn upside down (because you can and it keeps it out of eyes)
    clean prep and undercoat Wire wheel brush on screw gun works best IME
    see if you can find vehicles undercoat spray in can..I think theburtman has thread on it and brenndatomu and other offered advice
  3. brenndatomu
    It's hard to tell from pics, but I think I'd be hesitant to hit that with a needle scaler, at least until you know that it is solid enough to take it. A wire brush and a putty knife will probably be enough.
    But the rust converter and paint, yes...probably a good oil base paint then, like Rustoleum farm paint...personally, I prefer brush on paint for something like that.
    Rust-Oleum 1 qt. Farm & Implement J.D. Green Gloss Enamel Paint (2-Pack) 280108 - The Home Depot
  4. lukem
    I agree. You might end up with an inspection window in your deck.
    Even a flap disk might be too spicy. Start with a wire wheel and escalate as needed.
    RCBS, T.Jeff Veal, Skier76 and 3 others like this.
  5. Skier76
    Skier76
    CT and SoVT
    Thanks guys! I always appreciate the real world advice! I forgot to mention, I was thinking of hitting it with POR15 (underside of the deck)
    Would the brush on be better than spraying out of the HVLP gun?
  6. brenndatomu
    I think so, but either would work I'd say
    eatonpcat, T.Jeff Veal and Skier76 like this.
  7. Skier76
    Skier76
    CT and SoVT
    Thanks! I’m debating repainting the entire topside of the deck or just touching up the spots. I’m between “I want this to look even” and “Dude, it’s a lawnmower”.
  8. cezar
    cezar
    KY
    I pull my deck once a year and scrape everything out, wire brush everything, and then hit any surface rust with convertor. I don't bother with paint.
    eatonpcat, Skier76, Ronaldo and 2 others like this.
  9. Skier76
    Skier76
    CT and SoVT
    Thanks cezar…that looks great! Some solid advice.
    eatonpcat, Ronaldo and brenndatomu like this.
  10. Skier76
    Skier76
    CT and SoVT
    Well that escalated quickly… Looks like I’ll have to get this patched at some point. This is a bit beyond my welding “skills”.
    RCBS, brenndatomu and eatonpcat like this.
  11. The Wood Wolverine
  12. RCBS
    Take it off and get it to a welder. They can scab in patches. So long as the spindle area isn't compromised you can keep patching. Maybe a shade tree Auto Body man?
    I was ready to be on top of this problem when I bought my zero turn. Even bought a couple proprietary scraping tools. First fall I raised the deck to clean and found virtually nothing stuck to the deck. It's this way every year. There is residue, but so thin that moisture retention is of no thought. Very happy about this because I do not enjoy cleaning mower decks. I do occasionally mow 'moist' grass but so far have not had much issue with clingons.
  13. eatonpcat
    What mower?
  14. Skier76
    Skier76
    CT and SoVT
    Thanks guys! Will probably hire a welder for this. I may see if buzz-saw can help out.
  15. buzz-saw
    buzz-saw
    Ct.
    I
    Let me know if you would like me to at least take a look at it. It is a little hard to tell what is under that paint and how thin it is around the holes themselves.
    Skier76, eatonpcat and brenndatomu like this.
  16. Skier76
    Skier76
    CT and SoVT
    That would be really helpful! I’ll definitely take you up on that.
  17. JD Guy
    JD Guy
    Upstate SC
    I’m in the process now with cleaning my 62” mower deck on my JD X720. Have the underside cleaned out well of debris and now to begin with wire wheel. Just asking again are there any other procedures for prime/paint that I should consider. I didn’t clean out last year and I’m paying the price now:hair:. My thoughts are to wire brush best I can, spray with a rust oleum primer and then finish coat with a quality high gloss paint. Is this a reasonable plan? I want to avoid having a coating under there that might chip off which would make the job more difficult next year.. have considered taking deck and having lightly sand blasted to make sure it down to bare metal but don’t know if I can trust them not to get too aggressive. This deck weighs in excess of 200 lbs so not easy to move around. (Thank goodness for tractor and forks:thumbs:)
    Skier76 and brenndatomu like this.
  18. cezar
    cezar
    KY
    If you really care about quality I'd do wire brush / sandblast -> rust convertor -> POR15.
    I have POR15 _top coat_, not even the actual por15 product on my box blade and it has held up to GRAVEL SCRAPING. Stuff is insane.
    Total overkill though...
    JD Guy, Skier76 and brenndatomu like this.
  19. brenndatomu
    Grandpa used to scrape the deck out with putty knife, them clean up with a wire brush, then brush used motor oil in the underside...best parked on gravel or dirt then, or park on cardboard if you have concrete.
    JD Guy, Skier76 and Ronaldo like this.
  20. Canadian border VT
    I am becoming a believer in Por15 also
