60” Gravely Zero Turn - Thinking Used?
Discussion in 'Chainsaws and Power Equipment' started by wiguy, Apr 30, 2026.
  1. wiguy
    wiguy
    Wisconsin
    I was cutting wood today, what else? It was the rest of a sugar maple, lady lives alone. She tells me she has a new Toro mower coming today. I wasn’t a vulture, but asked her plans for the older mowers, she has 3. She told me she thought about putting the Gravely 60” zero turn out by the road, $500.
    This mower has had issues 1+ years ago, new fuel pump seemed to fix it. Now she says the battery drains when it’s off. I started & drove it, fired right up, no smoke, ran fine. My almost 20 y/o Cub Cadet is having issues, testing out later today. This Gravely could use some TLC, though it has been serviced in recent years.
    I have 5 acres here, mow kinda half of it. I don’t mind a little work if needed. I didn’t get the hours, she got it used I think a fair number of hours. It’s built like a tank, tires good. I know it’s not a lot to go on, but I’d think the $500 is safe from an equity standpoint, like I could always get it back.
    Any opinion on those versed with a Gravely mower? I could come to like the zero turn.
    Horkn, brenndatomu, Ronaldo and 3 others like this.
  2. JD Guy
    JD Guy
    Upstate SC
    I’ve heard they are good mowers but I’ve never owned one so take it FWIW. One consideration would be what year is it and are parts readily available?
  3. wiguy
    wiguy
    Wisconsin
    I don’t think it’s over 15 years old. Since it’s running fine, I think my $500 is safe. I don’t know the hours, thinking 700 or so. It was down for a while with the fuel pump issue, fixed now.
    Horkn, brenndatomu, eatonpcat and 2 others like this.
  4. jmb6420
    jmb6420
    Grand lake, Oklahoma
    Get it. Gravely is one of the best.
    My name is Mike, and I'm a hoarder in Ok.
    Lopi Endeavor and Republic 1250
    Horkn, brenndatomu, sms4life and 4 others like this.
  5. JD Guy
    JD Guy
    Upstate SC
    Well, I would go for it. The only catastrophic failure that might be costly would be the engine or possibly the hydraulics.
  6. Screwloose
    $500 is nothing for a ZT. Gravely is owned by Ariens and I'm able to get any wear parts for my 30+ year old mower.
    Ask her if you can mow with it and if both sides act the same your probably fine.
  7. Ron T
    Ron T
    Northeast Ohio....Bowdil
    What motor?
  8. Canadian border VT
    If it starts runs and cuts for 2 years how can you go wrong?
    gravelly especially if it commercial is well worth it
  9. wiguy
    wiguy
    Wisconsin
    Still in slight development, at the $500 level, I’m in.
  10. Skier76
    Skier76
    CT and SoVT
    I feel that’s a pretty low risk investment right there; especially if it runs and cuts. If you get it, give it a good once over and check all the fluids and filters. Cheap insurance.
  11. eatonpcat
    Buy it....
  12. Ronaldo
    Ronaldo
    I’d be on it like a duck after a June bug.
  13. brenndatomu
    Seems likely to be a good deal...know the model?
    Horkn, Ronaldo, eatonpcat and 2 others like this.
  14. wiguy
    wiguy
    Wisconsin
    Ok, went & picked up the mower, had to remove the discharge chute to fit in my trailer. So far I put on a few missing deck bolts, lubed & did an oil change of sorts. The oil was low & warm, with the quick drain I drained it then added fresh, I’ll get the filter later.
    I got attachments I’ll never use, sorting things out. Tires needed air. The SN dates to 2017-2018 online. It’s a beast, dirt simple to adjust the cutting height. The engine sounds great, 2700 hours on the meter, seems a little high. I got a bunch of blades with it, will try harder later to get one of the blades off the spindle. The blades on the deck could use attention, sharpening.
    With the 60” cut it makes short work of my yard. I haven’t found a grease zerk yet, the web says may not be any. There are none on the spindles, not even the front wheels, zero.
    jmb6420, eatonpcat, JD Guy and 5 others like this.
  15. Will C
    Will C
    New York
    I had an engine blow up on a Toro commercial zero turn 2 years ago. It had 1600 hours on it. One of the hydros was weak. I decided to buy a new one. I got $500’for that with full disclosure of the problems. I say you did well.
    jmb6420, eatonpcat, Horkn and 3 others like this.
  16. brenndatomu
    Yeah that seems like a pretty good deal! Hydrogear 3100 drives...nothing wrong with that...those are serviceable and each have a filter.
    I nominate you for the May 1st "you suck" award...can I get a second? :D
    jmb6420, eatonpcat, Horkn and 4 others like this.
  17. Canadian border VT
    I second that
  18. Skier76
    Skier76
    CT and SoVT
    I’ll second that! A great score! Congrats! Looks like a solid machine.
  19. wiguy
    wiguy
    Wisconsin
    I have to work a bit. The next thing I want to check is spindle condition. The blades are mediocre also, they could be replaced or sharpened too.
    I looked at a few spindle videos, done them before. I mostly want to check first, not blindly replace.
  20. Screwloose
    Nice mower! Looks to be a solid deal.
