Husky 359
Discussion in 'Chainsaws and Power Equipment' started by mr.finn, Apr 28, 2026.
  1. mr.finn
    mr.finn
    Mass
    Hello all. I need some advice. My brother found a 359 helping clean out a building. He gave me the saw and I didn't really think much of it at the time. Finally got it running last year and it's not a bad little saw. I Have other saws, but hearing good things about these after some modifications. Do these saws port well? If so any builders recommended? I didn't want to post this on FB to a bunch of random people, I trust this group much more. Thoughts?
    Reloader, MAF143, M2theB and 6 others like this.
  2. Eggshooterist
    Eggshooterist
    Erff
  3. farminkarman
    farminkarman
    Neenah, WI
    Yes, they port well. As Eggshooter said, send it to huskihl
    Reloader, Screwloose, MAF143 and 5 others like this.
  4. Ronaldo
    Ronaldo
    A muffler mod will help these too. Most 359’s were equipped with a catalytic muffler that holds heat and slows exhaust. They are very nice saws.
    mr.finn, Reloader, Screwloose and 6 others like this.
  5. huskihl
    huskihl
    Great saw. The semi pro version of the 357XP. I am in the Facebook groups too, and I understand your frustration with inquiring about it on there. Send me a PM if I can help you out
  6. M2theB
    M2theB
    Central Massachusetts
    for reliability, make sure it has the metal intake clamp, not the plastic snap version. Also some of these had the auto decomp valve. If so, plug the cylinder on both ends of the set up.
  7. Reloader
    Reloader
    NW Oregon
    Is holding heat an intentional thing they do? If so, what purpose does it serve?
    Eggshooterist, eatonpcat and huskihl like this.
  8. farminkarman
    farminkarman
    Neenah, WI
    I believe the whole idea was to help burn off more of the hydrocarbons on their way out.
  9. Jeffrey Svoboda
    Jeffrey Svoboda
    Nevermind the longevity of the unit. Gotta have clean exhaust fumes.....
  10. Ronaldo
    Ronaldo
    Holding heat is a byproduct of catalysts and that heat, then helps to burn off more nasties.
  11. Duane(Pa)
    Duane(Pa)
    Centre Co.
    Oh hell no! EPA emissions BS
    huskihl, Eggshooterist and eatonpcat like this.
  12. Duane(Pa)
    Duane(Pa)
    Centre Co.
    This… I always thought the cat muffler had a media in it. My friend (Bubba) cut a big hole in the side of one and the view is amazing. The cat is a perforated plate in the exhaust stream and it glows bright red in anything other than a limbing cut. Cooks off some hydrocarbons before exiting the factory outlet. I’m not too concerned with emissions, just want less restrictive exhaust.
    eta A hollow can muffler is an easy get for a 359 and the guy porting it will make the right size outlet.
