Where to Buy Chains and What Type?
Discussion in 'Chainsaws and Power Equipment' started by RichE23ACR, Apr 23, 2026.
  1. Eric Wanderweg
  2. Eric Wanderweg
    I'm one click away from pulling the trigger on 25' of factory square ground from Frawleys in Iowa, who seem to have it cheapest. They're another place that I have zero complaints with. It beats giving my business to Jeff Bezos.
    72CL025U 25' 3/8 pitch Square Ground Chisel saw chain .050
    EDIT: Ordered. :emb: Free shipping!
  3. The Wood Wolverine
    Frawleys has never disappointed me, plus I like supporting small businesses. The factory angles on that chain won’t be the best you’ve ran, if you’ve never tried it before. Not implying it won’t cut for chit.
  4. Eric Wanderweg
    I figured it was ground more for durability than speed, which is fine. After the first sharpening I’ll give the side plate some more forward lean, and maybe the top plate a steeper angle depending on where it’s at. The main thing is that I won’t have to trash my wheel converting round to square when it’s time to sharpen.
  5. Eggshooterist
    Eggshooterist
    Erff
    I use the Dukes 3/8lp. I consider it as close to stihl chain as you can get. In fact, if he ever offers a Stihl 23RSP style, I'll be using it instead of said 23RSP. All my saws run the 3/8LP except one. That's the one I run the stihl chain on.
    eatonpcat, brenndatomu, Chud and 3 others like this.
  6. buZZsaw BRAD
    I run Stihl RS full chisel on my saws. Ill look for deals on eBay/FBM. One thing I've recently done thanks to Eric Wanderweg is buy longer chains at a discount and he shortens them to 20/25". Matter of fact I have a deal in the works for seven 20 & 28" chains for $30. FBM find that I need to meet up with. Seems its easier to buy more than have a sharpen-a-thon.:emb:
    I have used Oregon and Carlton in the past but have settled on Stihl.
  7. Canadian border VT
    So it has to rain some time, I got a dozen or so needing sharpen, My guy, I previously talked about an old timer, spun chain and sharpened chain. He could smoke in his shop, got cataracts can’t see to do it anymore.
  8. Screwloose
    Seems like an equipment buying opportunity to me.
  9. Canadian border VT
    Already discussing with him over cigar and bourbon
    Hoarders think same way… Lot of stuff where to put it all:hair::hair:
  10. Eric Wanderweg
    My factory square ground just came in this afternoon. As expected, the angles aren’t too aggressive, but it should still cut faster and smoother than any round chain will off the roll. The top plate angle is conservative and the side plate looks to be 90 degrees vertical. I think the grind looks halfway decent though :thumbs:
    ole, buZZsaw BRAD, Duane(Pa) and 3 others like this.
