Poison Ivy
Discussion in 'The Wood Pile' started by ReelFaster, Mar 19, 2026.
  1. ReelFaster
    ReelFaster
    S.Jersey
    Wood score I had about two weeks ago I posted about, well some of it had some poison ivy vines on it.
    I was careful and pulled most of it off but probably didn't get them all. My question is should I axe off what I see and can find still attached to the rounds or just let those rounds sit for a loong period of time and let it die/dry up on it's own.
    Chvymn99, metalcuttr, John D and 6 others like this.
  2. Eric Wanderweg
    My SOP with those vines is to avoid cutting them with a saw as much as possible. I don’t want the dust and oils from them getting airborne and covering everything. I pry them off as best I can, but as for the little hairy remnants that get left behind, I don’t worry about them. I haven’t had any issues yet when they do go into my stove a couple years later.
  3. ReelFaster
    ReelFaster
    S.Jersey
    Thanks for info, I probably should have thought of that when cutting :doh:
    Would like to get it split to start drying but I know I'll loose track of being careful and probably end up with that crap on me somewhere somehow. The stuff is a PITA seems to get everywhere!!!
  4. RCBS
    I am sure to get it all off before it hits the burner. When I was a kid a couple girls in the neighborhood had a run in with some poison ivy smoke at an outdoor get together. One had it IN her ears and nose, the other had some on back of her throat and in nose. :jaw: If I hadn't lived through it I would likely argue that it's impossible. I don't really get poison anymore but when it comes to smoke, I mitigate out of fear.
  5. isaaccarlson
    isaaccarlson
    Colfax, WI
    Yep, can happen. They say it can happen if you mow it too, but I have mowed a bunch in my life and I keep my face inside my shirt and mow downwind.
  6. T.Jeff Veal
    We have cut some BIG PO/PI vines. When using the saw, I try to use the top of the bar and lower speeds, to clean area for notching. Sometimes use the axe and hookaroon to cut/pull vines off once trees are down. I've also worn disposable coveralls and gloves when dealing with big amounts of it. It can be a pain. Grapple works great for removing vines too.
  7. Backwoods Savage
    There seems to be lots of that stuff no matter where you go. I don't worry much but try to be a little careful. If it is too thick I just leave it and cut somewhere else. I've cut many trees with it and try to be very careful. I'll get enough off so I can drop the tree then get more off but rarely do I get it all. I have wood in the stacks now that have it but they are small vines. I just throw those in the stove along with other wood and don't worry. I've not had a PI itch now for many years.
  8. jrider
    jrider
    I'd say it depends on how bad you get it. For me, it all needs to come off. Every time I am exposed, I end up on Prednisone.
  9. The Wood Wolverine
    For me, it all comes off. I try to separate before bucking if I can. If not, I do it before loading. I never used to get any reaction to poison when I was younger but the older I get, the worse I get it.
    metalcuttr, T.Jeff Veal and eatonpcat like this.
  10. ReelFaster
    ReelFaster
    S.Jersey
    Honestly, this is the first time I've gotten it. Itching hasn't been terrible and tolerable. Sometimes it seems to flare up and I want to scratch the chit out of it, but I put some aloe on it and it soothes it quick.
    But the one thing I noticed is my one arm is swollen like a son of a gun on one area, almost looks deformed but has subsided a bit now almost a week later.
    metalcuttr and T.Jeff Veal like this.
  11. jrider
    jrider
    Next time you’re in the shower crank the hot water as high as you can stand it and put the arm directly in the flow. Resist the initial urge to scratch and you’ll get a very satisfying relief.
  12. Locust Post
    I try to remove what I can but don't stress over it. If I feel any itch start I scrub the area with bleach then with soap and water.
  13. Eric VW
    If you’re worried, get some “cleaning strength” vinegar in a bug sprayer, spray what vine remnants you can’t remove.
  14. buZZsaw BRAD
    Still toxic even after its dry. Id leave and take off when you split/stack them using hatchet or machete.
    I don't get it often and when I do its on my forearms when wooding with short sleeves on. I am very mind full around it too.
  15. billb3
    I used to pull any vines off with pliers.
    Then I sprayted the pliers off with something like brake cleaner or carb cleaner. I forget what now.
    A hatchet sounds good, too.
    Supposedly the urushiol oil can persist for a very long time.
    The oil is even in the roots.
  16. metalcuttr
    metalcuttr
    western WA
    Deathly allergic to the poison oak we have around here. Last time I unknowingly got into it I had to have prednisone shot AM and antihistamine shot PM with pills in between for a week and a half Before it became manageable. Got it in my crotch and eyes as well. Everything was all swollen up. Got to admit though, I had some pretty impressive attributes for a while!:bug: If firewood even has a hint of PO on or around it I won't have a thing to do with it!
  17. ole
    ole
    Rock County Wisconsin
    there is one heckuva of a reply here but I can’t post it on a fam friendly forum :heidi:
    I even had it typed out
  18. ole
    ole
    My G - rated reply is my old line foreman put his two granddaughters in the hospital by burning poison ivy vines in his backyard fire pit. It was horrible.
  19. Eric VW
    You’ll have to PM it to our resident weirdo, aka eatonpcat … who might have to change his screen name to eatondingdong…
    :rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
  20. metalcuttr
    metalcuttr
    western WA
    Been there done that also. A beach fire with some viney logs sure messed up an early marriage vacation!
