Boat repair
Discussion in 'Everything Else (off topic)' started by Eggshooterist, Mar 22, 2026.
  1. Eggshooterist
    Eggshooterist
    Erff
    I aquired a 12ft aluma craft or alumilite boat today with trailer. It needs new transom wood and hardware. Any recommendations on the correct wood to use? Treated plywood? A specific marine plywood? It's missing the outside piece but I can see the outline of where it used to be. The inside piece is there but getting bad. It looks like a 2x6. The hardware is rusted out so I'll replace that with stainless. I've never owned or worked on a boat so this will be a new experience. I have a 6hp Johnson to hang off the back.
    metalcuttr, RCBS, yooperdave and 6 others like this.
  2. Ohio dave
    Ohio dave
    Akron, OH
    There are actually different grades of treated plywood. You should use marine grade. Regular pt is will work for a short period of time
  3. Eggshooterist
    Eggshooterist
    Erff
    I just read that traditional pressure treated construction wood shouldn't be used on aluminum boats because it eats the aluminum. I'll definitely be looking for marine plywood.
  4. Perry long jr
    Perry long jr
    Eastern, Kentucky
    I purchased an aluminum boat some years back. the original owner had used pressure treated plywood in one part of the boat. It had pitted the aluminum. I had to get some specialized coating to fix that area. Pressure treated wood is corrosive to aluminum. Get the marine stuff and you will be fine
  5. Eggshooterist
    Eggshooterist
    Erff
    Thank you. That's the plan after some research.
  6. Wolley
    Wolley
    I used oak on my grumman. White oak is better if you can get it. Lots of different woods are used in boats. Varnish it or oil it, will make it last a long time
  7. Eggshooterist
    Eggshooterist
    Erff
    That was another question I have. Spar Urethane? Something else? Some online say fiberglass resin.
  8. Backwoods Savage
    Good luck and have some enjoyment with the boat. Is the snow gone yet?
  9. Eggshooterist
    Eggshooterist
    Erff
    Yep. All gone.
  10. Backwoods Savage
    Hooray! Not only happy about the missing snow but we're only a month away from this year's GTG!
  11. Canadian border VT
    yes here when rebuild bathroom window framings due to rot, PT was first choice, I remember when the said no to metal flashing on PT which is aluminum
  12. Eggshooterist
    Eggshooterist
    Erff
    Yes. I'm greatly looking forward to it
  13. Screwloose
    Glad you said that....I was thinking about using it on my boat.
  14. Screwloose
    What about plastic? I was thinking about something UV resistant and putting counter bored holes for the clamp pads on the motor to sit in.
    My boat is also a 12' aluminum and the transom wood is gone.
  15. Eggshooterist
    Eggshooterist
    Erff
    If I could find something stiff but not brittle that was as thick as I need, I'd try it. The inside board is probably 1.25" thick or more. The rear is missing but the hardware is still there. That looks to have been 3/4" or so based on what's protruding of the bolts.
  16. yooperdave
    I also had an aluminum boat with rotted transom wood. The boat was stored upside down during winter months and the transom would be covered in snow just a few inches off the ground. Got about 25 years from the mount before having to replace it.
    I used what was around and gave it a coating (or three) of varnish. Didn't last anywhere near as long as the original, but by then, the boat was only used as a row boat.
    I would go with marine plywood in your case. :handshake:
  17. Eggshooterist
    Eggshooterist
    Erff
    Is marine plywood available at places like home depot or do I need to go to a boat specific repair establishment to aquire it.
  18. moresnow
    moresnow
    Coosa board
    check it out
    widely used in your required application
    May be overkill but this will give you a rabbit hole to dive into!
    I have a 12-footer that needs the same attention. Handy little unit with an old '82 Johnson 7.5 hp 2 smoker. Actually, been thinking of rehabbing the setup and getting some regular use out of it!
  19. Eggshooterist
    Eggshooterist
    Erff
    Thank you. I'll look into it.
  20. billb3
    Just do an internet search. The closest HD to you that has it should pop up. About a 20 minute drive for me and I live in a town with a popular harbor and quite a few marinas. Go figure. Our HD is a bit smaller than others and that is probably why. Been a long time since I had to do any fiberglass work. I had a dinghy that would get beat up, mostly from dragging it across somewhat rocky/not sandy beaches. I'd wear out the rub rails on the bottom. :)
