22 ton Oregon splitter
Discussion in 'Chainsaws and Power Equipment' started by Paul Dokken, Mar 14, 2026.
Tags:
  1. Paul Dokken
    Paul Dokken
    Waxhaw NC
    The last time I used my splitter was in winter and the forward and reverse lever would stick. Usually it only reverses without me pushing the lever but it was sticking in the forward position. Before I try to use it again does anyone have any suggestions? Should I spray WD-40 on the valve? I've got a lot of oak to split and it seems like a safety hazard this way.
    John D, Screwloose, RCBS and 3 others like this.
  2. Stephiedoll
    Stephiedoll
    Omaha, NE.
    No solution from me, but I wonder if your oil has water in it and causing the problem. One thing I can offer, is a friend gave me a spare that I don't see me needing anytime soon so let me know if that helps.
  3. Paul Dokken
    Paul Dokken
    Waxhaw NC
    This is what mine looks like.
  4. brenndatomu
    Screwloose, RCBS, EODMSgt and 4 others like this.
  5. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Here are some pictures of the Speeco unit I have. Probably easier to repair yours's but let me know. 20260316_053807.jpg 20260316_053815.jpg 20260316_053824.jpg 20260316_053838.jpg 20260316_053857.jpg
  6. RCBS
    You can pull the rod out and spin it 180 degrees to get out of the worn grooves for the detents. Unknown if that will fix the stuck forwards but will allow cleanup at least. I did this once on my last splitter and got some more time out of it.
  7. Paul Dokken
    Paul Dokken
    Waxhaw NC
  8. Paul Dokken
    Paul Dokken
    Waxhaw NC
    Good idea. I will try this.
  9. Paul Dokken
    Paul Dokken
    Waxhaw NC
    Lots of good ideas to try. I will post what the fix is when I get time to try these.
  10. Paul Dokken
    Paul Dokken
    Waxhaw NC
    I bought an O-ring rebuild kit. I am wondering if the ball bearings every wear out. I took the cover off and it looked the big ball in the middle was still in place. There was some dirty oil all over the assembly so I am guessing the o-rings are the culprit.
  11. Paul Dokken
    Paul Dokken
    Waxhaw NC
    metalcuttr, eatonpcat and brenndatomu like this.
  12. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Shoot me a PM with address and I will see about getting it sent out. We can settle up later if it works for you.
  13. Paul Dokken
    Paul Dokken
    Waxhaw NC
    I was able to use parts from another valve (thanks Stephiedoll !). It seems to work fine except it won't put any pressure on the wood I am trying to split. Could it be air in line? Any ideas? Here is a video of it operating
    eatonpcat likes this.
  14. brenndatomu
    And it was fine before?
    That sounds like the relief is set too low now...but that's on the pump, and you didn't mess with that, did you?
    It almost has to be that, or the cylinder is bypassing internally (piston seals) either way, weird if it just started after working on the valve...the only adjustment in there is the detent relief pressure as far as I know...
  15. isaaccarlson
    isaaccarlson
    Colfax, WI
    Wd40 dries to a film and is not a lubricant. It is a rust preventer.
    brenndatomu likes this.
  16. Paul Dokken
    Paul Dokken
    Waxhaw NC
    It worked fine before I worked on the valve and the detent seems to work fine. Any other suggestions on what to check?
  17. brenndatomu
    Well, the way to see if the cylinder is bypassing is to put a piece of wood in it, run the wedge up tight against it, unhook the return line from the cylinder (front line when pushing) then try to split the wood...see if oil comes out the front port without the cylinder extending...if it does, then the piston seals are bypassing...but I don't see how that could suddenly happen right after working on the valve detent, when it was fine before?!
    I suppose the pump coupling keyway could have sheared...maybe when the detent stuck? That'd be a bit of a freak coincidence if it did though...
    eatonpcat and John D like this.
  18. Paul Dokken
    Paul Dokken
    Waxhaw NC
    I figured it out. I had one of the o-rings in the wrong position.
  19. isaaccarlson
    isaaccarlson
    Colfax, WI
    That would do it…
    eatonpcat, brenndatomu and theburtman like this.
