Pallet forks for your loader, (Thoughts)?
Discussion in 'Chainsaws and Power Equipment' started by WeldrDave, Feb 2, 2026.
  1. Woodtroll
    Woodtroll
    Mtns of SW VA
    Stupid question about those bolts in the end of the forks - when I first saw them a while back I wondered how you managed to get the logs on the forks with those things in the way. The "welded washer" comment jogged another thought, though - I guess you drop the bolts down in the holes after you scoop up the logs, and the washers hold them in place rather than them actually being "bolted" in place?
  2. T.Jeff Veal
    Correct, leave bolts at splitter, go to log piles, get what logs the tractor will handle and return to splitter, Miz Carol drops bolts in forks, I tilt forks down until level or slightly lower, roll logs down to bolts and cut into rounds.
    See the other picture with big log, before bolts are dropped in
  3. WeldrDave
    Super Pictures guy's!!! really nice! :cool::):yes:
  4. Woodtroll
    Woodtroll
    Mtns of SW VA
    That makes sense, thanks. From earlier photos I always thought they were bolted on - I guess because they sit so straight and upright. It was your almost-random comment about the washers that clicked the light bulb on for me. Thanks for the reply!
  5. WeldrDave
    Sorry this took a couple days but I got just a couple pictures of the welds I was telling you about. I can't get to the back side because it's on the loader but you'll get the Idea. Here's a couple shots of the gusset's area. As you can see, they are HIDEOUS!! I am going to write a letter to them with some good printed pictures, The back is just as bad if not worse in some spots. Places in the corners are atrocious! :picard::eek:o_O
  6. Jeffrey Svoboda
    Jeffrey Svoboda
    Somebody wasn't trying that day.
  7. WeldrDave
    I also bought this Fork lifting system from Home Depot!, Price was $82 bucks. I can't build it for that... Sadly it's made in China but it's from a company called Vevor. It seems well made, welds are fine and it's rated at 4400lbs. I'll NEVER max this out lifting logs! :).
  8. brenndatomu
    Classic chicken chit welds!
    I've seen way better from freshman year ag class welding!!
    isaaccarlson, Ron T, FTG-05 and 9 others like this.
  9. Screwloose
    I'd send it back on their dime that's ridiculous. I'd be embarrassed to have people see it.
  10. Stinny
    WeldrDave ... how do you like your Yard Max? They're quite a rig...
  11. WeldrDave
    My Track Buggy is awesome!!! :cool: Vibrates alot but par for the coarse...
    Stinny, Screwloose, eatonpcat and 4 others like this.
  12. WeldrDave
    I agree! But for what I paid, it wouldn't be worth the aggravation. Yes, those welds are HORRIBLE! When the weather warms up, I'll run some passes over them. I'll know it's fixed right then...
  13. T.Jeff Veal
    I like that, might look into getting one for our tractor.
  14. WeldrDave
  15. T.Jeff Veal
    Chud, Chvymn99, Screwloose and 4 others like this.
  16. eatonpcat
    I need one of those...Mz Carol seems to approve all expenses!
    isaaccarlson, Chud, Chvymn99 and 5 others like this.
  17. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I have a Fort Knox safe that is 1200# empty
    Chud, eatonpcat, Chvymn99 and 5 others like this.
  18. Screwloose
    I can send you my arcair and some electrodes. You can sweep up their welds and mail them back.
  19. Screwloose
    I really need to get a safe. Stuff tucked everywhere.
  20. Screwloose
    So I have one, albeit much older. Because of the taper on the forks you can't get them to stay put. You get it tight and the first lift it wiggles down the fork. Rig up a short chain to fix the distance from the frame and the problem goes away.
