Radio Control Model Hobby
Discussion in 'Hobbies and Interests' started by Eggshooterist, Jul 6, 2025.
  1. buzz-saw
    buzz-saw
    Ct.
    Not sure if exciting is the right word , It will certainly be different. And learn; yeah I think I will have a lot of that to do.
  2. Eggshooterist
    Eggshooterist
    Erff
    Looking good.
    Eric VW, brenndatomu and eatonpcat like this.
  3. buzz-saw
    buzz-saw
    Ct.
    I like the tires and wheels. Aggressive tread pattern!
  4. Eggshooterist
    Eggshooterist
    Erff
    Do they have some sort of stabilizer like the Losi dirt bike flywheel?
  5. buzz-saw
    buzz-saw
    Ct.
    No , I am the stabilizer. That will keep it interesting.
    I don't expect this to be quite as easy as the Losi with the flywheel and gyro. Losi almost made it too easy.
  6. Eggshooterist
    Eggshooterist
    Erff
    This will be interesting to hear about. Please share when you get some trigger time.
  7. buzz-saw
    buzz-saw
    Ct.
    Sure thing.
    With the snow we have around here and some wicked cold it might be a while.
  8. Eggshooterist
    Eggshooterist
    Erff
    Same here. Im not taking any of mine out in this shiz.
    Eric VW, brenndatomu and buzz-saw like this.
  9. buzz-saw
    buzz-saw
    Ct.
    Quick picture with a rider. Waiting impatiently for spring!
    Eric VW, eatonpcat and Eggshooterist like this.
  10. Eggshooterist
    Eggshooterist
    Erff
    Very cool bud.
    Eric VW, buzz-saw and eatonpcat like this.
  11. Eggshooterist
    Eggshooterist
    Erff
    Back on the Kyosho Optima re-release buggy. I mounted the rest of the electronics, motor and pinion gear and soldered the battery plug on the ESC today. Tomorrow I'll solder the motor wires on then test / adjust. Painting is all that will be left after that.
    eatonpcat and buzz-saw like this.
  12. Eggshooterist
    Eggshooterist
    Erff
    Ready for body paint.
  13. Eggshooterist
    Eggshooterist
    Erff
    Same for this one.
  14. Eggshooterist
    Eggshooterist
    Erff
    To improve ground clearance, breakover angle and traction, I purchased the largest crawler tires that fit the factory wheels. I have 20mm hub extensions inbound to keep them from snagging the shock springs. These tires are significantly larger and more aggressive than the oem rubber.
    20260225_165950.jpg 20260225_165957.jpg 20260225_170008.jpg 20260225_170050.jpg 20260225_170111.jpg
  15. Eggshooterist
    Eggshooterist
    Erff
  16. eatonpcat
    Beautiful...That is some serious articulation!
    Eric VW and Eggshooterist like this.
  17. Eggshooterist
    Eggshooterist
    Erff
    Thanks bud. The 20 mm extensions should increase it some. More leverage over the suspension.
    eatonpcat and Eric VW like this.
  18. Eggshooterist
    Eggshooterist
    Erff
    Back on the boat. I installed motor wire plugs and battery plugs. I need to purchase a length of 12g wire to complete the circuit to run two batteries in series. 20260303_090541.jpg 20260303_090505.jpg 20260303_090639.jpg 20260303_090702.jpg
    Eric VW and eatonpcat like this.
  19. Eggshooterist
    Eggshooterist
    Erff
    And my latest acquisition.
    Eric VW, eatonpcat and buzz-saw like this.
  20. buzz-saw
    buzz-saw
    Ct.
    Eric VW, Eggshooterist and eatonpcat like this.
