What goes up must come down...?
Discussion in 'The Wood Market' started by CutSplitStack, Jan 27, 2026.
  1. CutSplitStack
    CutSplitStack
    So today I delivered to a regular customer, she orders a face cord at a time and when she isn't home she provides a garage code. I stack the wood in a rack she has in the garage, close the door when I leave, and text her to let her know it's all wrapped up. But today the door would not go down! Seems the eye was the issue. Never considered the problem of being able to get into a customer's garage and then not be able to secure it again! Anybody have similar stories?
  2. chris
    I have one door that at late afternoon refuses to stay closed gets almost there and then reverses -sun into photo eye, even have a shade tube on it, reset it many times . it is very sensitive to any pressure on the down stroke as well. at this point it is mute because the plastic drive gear shattered due to-30 F cold. Both of my openers are over 20 years old so likely will replace when things warm up. dosen't take much for the eyes to get out of alignment and then cause closing problems on any of them.
  3. billb3
    I have had to pull the little rope that unlocks the lift traveller from the door and close the door manually. All chain drives.
    I've also had no power and had to do the same.
    Course, now with the door disconnected from the drive anyone could come along and open it. It could be manually locked from inside, but the next person would have to know the door is manually locked. Plus sometimes the garage door is the only way out without going into the house.
  4. Jeffrey Svoboda
    Jeffrey Svoboda
    I've seen the eyes mounted on the header about 2 feet apart. The door works much better that way.
  5. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    That is sheer genius
  6. Jeffrey Svoboda
    Jeffrey Svoboda
    Can't say it's my idea but most every garage door I was around as a kid was set up like this. I'm just surprised I don't see more. Actually I almost never see it now that the world is all safety this and safety that. It's like they're trying to create more stupid, unaware people. Seams survival of the fittest is no longer a thing.
    Chaz, T.Jeff Veal, metalcuttr and 4 others like this.
  7. Sandhillbilly
    Sandhillbilly
    My garage door “eyes” are just above the floor and always getting bumped or covered with cobwebs and leaves and grass clippings. You can bet your favorite chainsaw that they’s gonna get relocated once the weather warms up. Don’t know why I never thought of this. Never seen one set up like that before.
  8. chris
    when i replace these two the eyes will be mounted up high right by the drive box.
  9. isaaccarlson
    isaaccarlson
    Colfax, WI
    Just be careful. The eyes are meant to prevent crushing kids, pets, or items. I understand both sides of the issue, but I have to say it….
  10. Jeffrey Svoboda
    Jeffrey Svoboda
    Usually the openers are build with a pressure sensitive reverse for when an obstacle is detected in the path of the door. Safeties on top of safeties. It's just a replacement for common sense.
  11. isaaccarlson
    isaaccarlson
    Colfax, WI
    Yeah, but I put one in for a guy last year and even after setting the stop distance, it would drive the door into the floor and crush the top of it where the link mounted and bend the chain rail up like a rainbow. Something was bad on the control board and it lost track of where it was supposed to stop.
  12. Elm-er Fudd
    Elm-er Fudd
    Kansas
    My garage doors eyes are mounted about 6” apart on the hardware that suspends the motor and drive from the ceiling. Never get blocked with leaves and debris.
    Chaz, Haftacut, T.Jeff Veal and 2 others like this.
  13. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Chaz, WeldrDave, brenndatomu and 4 others like this.
  14. stoveliker
    stoveliker
    Eastern Long Island
    But what's the point of that. Why not jump the connection on the board. Less chance of things malfunctioning then ...
  15. Ron T
    Ron T
    Point is there are no sensors on the floor to get jacked up. Quick and simple
  16. stoveliker
    stoveliker
    Eastern Long Island
    Yes but then I'd have shorted them out rather than putting them on the ceiling. If you don't use them why go thru the effort of mounting them someplace...
    brenndatomu and T.Jeff Veal like this.
  17. Jeffrey Svoboda
    Jeffrey Svoboda
    How do you know that jumpering them at the control head wouldn't literally short out the board and cause other problems. Most modern electronics aren't just a simple on/off switch. Why take the chance....
  18. Ron T
    Ron T
    4 screws and a ladder....im not that pressed for time.
  19. stoveliker
    stoveliker
    Eastern Long Island
    It's a simple binary thing. Either there is a signal at the connections on the board or not.
    Anyway, 4 screws isn't much but ...
    Many ways to do things.
  20. Haftacut
    Haftacut
    Rives Junction, MI
    Both my doors set this way:rofl: :lol:
