Horizon Eclipse pellet stove manual available
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by 343amc, Oct 4, 2013.
  1. 343amc
    343amc
    Northeast Lower Michigan
    I have manuals for the Horizon Eclipse pellet stoves (from the early to mid 1990s) available in electronic format if anyone is in need of them. Send a PM or reply if you have a use for a copy.
    smoke show and jtakeman like this.
  2. michael
    michael
  3. 343amc
    343amc
    marshallb likes this.
  4. marshallb
    marshallb
    easton pa
    i could really use the manual. i really need the install guide showing the clearance to combustibles. the link you provided above does not work. thank you. my email is [email protected]
  5. 343amc
    343amc
    The link only works for a week or two. Darn free file sharing sites anyways.
    I'll get it uploaded when I'm back in front of my computer and post a new link.
    Welcome, by the way.
  6. 343amc
    343amc
  7. marshallb
    marshallb
    easton pa
    worked fine! thanks so much!!
  8. 343amc
    343amc
    You're welcome. The only things that aren't in there are the mobile home install instructions. If you need those let me know. I went real high tech with the manual - just took pictures of the pages with my phone.
    Good luck, and if you have any other questions, feel free to ask.
  9. marshallb
    marshallb
    easton pa
    the only thing that is not included in the manual is the clearance to combustibles. like how far to set the stove off the walls. the manual printed out real nice. must be the high tech methods of copying the images. :thumbs: if by some chance you have that it would be greatly appreciated.
  10. 343amc
    343amc
    There are a bunch of .jpg files inside that zip file. I thought the clearance to combustibles was in one of those pictures.
  11. marshallb
    marshallb
    easton pa
    i found it in a zipped file. all the clearance info is in there. :D
    343amc likes this.
  12. Tommy Moe
    Tommy Moe
    Nashville
    Anyone have a wiring diagram for the control panel on this stove - (Horizon Eclipse)?? Or a pic of the back of it wired correctly. I am following up - not knowing exactly how this should be and I'm sure I'm not close. Thanks - Tom
