Heast Master G200 update
Discussion in 'OWB's and Gasification Boilers' started by farmer rob, Jan 24, 2026.
  1. farmer rob
    farmer rob
    Dundalk Ontario Canada
    Hello just a quick review of the unit.I installed it and began using it winter of 2022 worked good since then amazing how little ash comes out of the fire box.
    2025 I started it in early Nov and as of today have not yet taken any ash out of the fire box .
    Now the bottom area gets cleaned every few weeks but that is so fine & the heat ex changer tubes are so easy to clean with just a few moves of the handle.
    I have been burning a mixture of birch poplar maple & spruce loaded it last night at 6 pm now its 1030 am and still have not put any in so cannot complain since house is set & 74 degrees & last night was -25C
    morningwood, brenndatomu and JD Guy like this.
  2. brenndatomu
    Did you buy a new leftover G200, or get it used?
    I only ask as I know the G4000 took it's place in 2020.
    Sounds like it's working fantastic for you! :yes:
  3. farmer rob
    farmer rob
    I bought it new during Covide as it is put in my attached garage when we built the new house & since the lumber prices were crazy that never got completed till Sept 2022
    stuckinthemuck and brenndatomu like this.
  4. lukem
    G200 is a solid unit. I've been burning mine for a long time and have never emptied ashes from the fire box. I empty the bottom chamber about 2 or 3 times a year.
    morningwood and brenndatomu like this.
  5. farmer rob
    farmer rob
    How often do you clean the chamber were the heat tubes connect to the chimney & have you ever had to replace that motor ?
  6. lukem
    Original fan motor. I clean the fan chamber once a year. You just reminded me that I haven't done it this year though.
    brenndatomu likes this.
  7. brenndatomu
    That area seems to cause a bit of trouble on the newer ones...especially if something is off and the unit is not gasifying correctly...
  8. lukem
    What kind of trouble?
  9. brenndatomu
    Plugging
  10. farmer rob
    farmer rob
    Thanks I was thinking of getting a spare motor just in case but being only my 4th winter was not sure. Yes that area is a pain to clean especially since its in my garage other wise I would use leaf blower even my shop vac makes a dust cloud.
  11. lukem
    I gave up on trying to get it spotless. I just get the majority out and run it. I think I tried the blower once and it was less than ideal. I might do mine this afternoon if it gets warm enough.
  12. lukem
    I cleaned mine out. It had quite a bit in the corners like it always does, but I don't see how this could get plugged up. Everything would just fall down the tubes.
  13. farmer rob
    farmer rob
    Have you ever had to burn out the creosote in the unit?
    I seem to always get the side panels out fairly easy in spring when done but getting them back in seems tricky even after pounding them flat again.
  14. lukem
    I've never taken my panels out.
  15. farmer rob
    farmer rob
    ok thanks the dealer told me to do them every year now sure why lol .
    Any issues with the bypass thing?I do not use it often but with furnace in my garage it will at time smoke a little more than I want when filling
  16. lukem
    Mine is a GS 200 and doesn't have the bypass.
  17. brenndatomu
    The best way to get the panels out, if you need to, is to pull them while the firebox is still warm (creosote still soft) and then leave the panels lay in the firebox until it cools...they won't warp so bad then, although it sounds like yours already are.
    Farmchuck likes this.
  18. farmer rob
    farmer rob
    A good idea thanks I never really have much issue getting them out but somehow the corner ones never fit nice going back in.
    I am going to try & burn out creosote this spring seen few clips filling unit with cardboard and making a fire any thoughts?
  19. lukem
    I burn a good hot cardboard fire once a week with the panels in.
  20. Farmchuck
    Farmchuck
    Nepa
    Not to change the subject but while we are on the subject of gasifiers how are your folks doing with they're G 10000?
