First year using Black Locust extensively.
Discussion in 'The Wood Pile' started by theburtman, Jan 26, 2026.
  1. theburtman
    theburtman
    This is the first year I've used the Black Locust I got in May 2022 on a regular basis. To be perfectly honest, I find it to require specific circumstances to burn well, without having to frig with it a lot. I'm going to start putting it in my overnight load one piece at a time mixed with other species, and not use it any other way for the most part. I would much rather have Shagbark, Ironwood, or bowling pin elm.
    metalcuttr, Horkn, Chvymn99 and 18 others like this.
  2. Yawner
    Yawner
    Louisiana
    How big do ironwood grow there? We have a lot here but it's an understory tree and they don't get very big. So, you find that it makes good firewood. I don't usually get any big enough to split, I usually get small diameter ones that I simply buck into 16" long rounds.
    What is bowling pin elm? Never heard of that.
  3. theburtman
    theburtman
    Bowling pin elm sounds like bowling pins when hit together. Usually standing dead limb wood. The biggest ironwood here is probably about 8 or 10 inch diameter.
  4. Yawner
    Yawner
    Louisiana
    Do you get quite a lot of ironwood for firewood? I guess I am having trouble envisioning getting much because it is not a big tree. Just ONE big oak or whatever provides a ton more firewood.
  5. theburtman
    theburtman
    Not a lot, but I grab it when available.
  6. BuckeyeFootball
    BuckeyeFootball
    I've had the same experience with BL but noticed the orange-ish colored stuff seems to ignite alot better/easier than then yellow stuff. Almost like ones a subspecies. The yellow once seasoned a few years is like coal lol.
  7. theburtman
    theburtman
    Yup!
  8. jo191145
    I tried BL one year seasoned,,,not good, needed more air to burn. Two years seasoned was better. Three years did the trick. Lights up without kindling, just a fire starter no extra air required. Maybe it just needs more time?
  9. theburtman
    theburtman
    The BL I got was mostly very dead(yellowish). The orange does ignite much better.
  10. theburtman
    theburtman
    This was all cut in May 22.
  11. Scotty Overkill
    I'd say almost 1/2 of my firewood stash is BL. It's one of my faves, especially for long cold nighttime burns. But my overall favorite wood to burn is white oak and ash mixed. Easly light up, lots of heat, lots of coals and smells great burning.
  12. JimBear
    JimBear
    Try putting about 2/3-3/4 BL & the rest pine.
    I really liked burning Ponderosa & Osage together.
    Osage & Cherry worked well together as well.
    I haven’t burned enough BL to try mixtures but folks talk like it burns similar to Osage.
  13. Locust Post
    My old stove (smoke dragon step stove) loved a gut full of bl but my newer cat stove I have to mix it in.
  14. buZZsaw BRAD
    Good friend of mine loves BL since I turned him onto it a few years ago. He was die hard hickory and red oak burner. Now he burns 2/3 BL and the rest oak heartwood. As far as I know he usually doesn't mix them.
    Of course everyone's stove is different and the best way to learn is through trial and error.
    I met a guy last week while delivering bundles and we had a chat about firewood. Turns out he was originally from Vermont and was familiar with it. He scrounges wood in his mid sized SUV.
  15. Eric Wanderweg
    I always burn it mixed for best results too. Beech, ash, oak, maple, poplar, pine, whatever.
  16. The Wood Wolverine
    This is the first time I’ve had a large amount of black locust too. Cut it Nov. ‘21, split in May of ‘22. I’ve fed my England’s full loads on multiple occasions. I’ve had great results. These splits are much heavier than the chestnut oak I’ve been using and last a good clip longer in the firebox. Every wood I have has no issues lighting up quickly. This isn’t a cat stove and it doesn’t have secondary air tubes for the record.
    It does smell pungent. Has to be the least desirable I’ve ever burned in that category. But I will continue to seek locust out and hoard as much as I can. I’m a fan.
    Next time I get out to the garage, I’ll grab my Isocore and split a split to check MC. I’d guess it’s in the 12-14 range.
    metalcuttr, Horkn, eatonpcat and 9 others like this.
  17. theburtman
    theburtman
    I'm thinking some of my problems with it are related to the fact that a large portion of it was dead and "petrified" when it was cut 3.5 years ago. The stuff that was green at that time burns better.
    metalcuttr, Horkn, eatonpcat and 11 others like this.
  18. The Wood Wolverine
    Interesting. Mine was cut live.
  19. MikeInMa
    A piece for overnight is how I use BL. Plenty of coals for easy morning relight.
  20. theburtman
    theburtman
    I think I will split some of the petrified stuff smaller and mix it.
    metalcuttr, Horkn, eatonpcat and 8 others like this.
