Water in Fuel?
Discussion in 'Chainsaws and Power Equipment' started by Ohio dave, Jan 18, 2026.
  1. Ohio dave
    Ohio dave
    Akron, OH
    My log splitter and one of my saws wouldn't start this morning. When I pull the cord I didn't even hear them cranking like they would if they were completely out if fuel. Could this be water that froze in the lines?
    metalcuttr, John D, eatonpcat and 4 others like this.
  2. Screwloose
    Its possible. Dump the saw out into a glass and see if any water shows up.
    metalcuttr, John D, eatonpcat and 6 others like this.
  3. BuckeyeFootball
    BuckeyeFootball
    Well isn't your saw a 2 stroke and splitter a 4 stroke? Why would you use the same gas in each?
  4. Ohio dave
    Ohio dave
    Akron, OH
    I have a 14 gallon gas container I buy non-ethonal in. Pump off a gallon at a time to mix my two cycle. The rest is used in my splitter and ride on
  5. Jeffrey Svoboda
    Jeffrey Svoboda
    Take a sample from the 14 gallon container. Fuel floats on water. So after the container has been sitting overnight, assuming it doesn't get moved much anyway. Syphon, drain, get about 12-16oz from the bottom and put in a clear container. Clear drink bottle of some sort works good. Let that fuel sit in the bottle for a couple hours and look for a separation line where the water and fuel separate.
    Something like this. Usually it's just a small line toward the bottom.
    metalcuttr, Haftacut, John D and 5 others like this.
