Clean Glass
Discussion in 'Modern EPA Stoves and Fireplaces' started by CNE deer, Jan 15, 2026.
  1. CNE deer
    CNE deer
    ohio
    OK Guru's why, when its single digits does the glass stay cleaner? I run the stove at the same temp ( stack temp) when its 20 it gets a lot of soot on the glass.
  2. CoachSchaller
    CoachSchaller
    Southeast Michigan
    Well I am no guru but my Ideal Steel has cleaner glass when I run it hotter. The glass wash works better and I have less smoke. I also think the hotter fire burns off the soot, leaving only white fly ash. However, this is the case for me with different temperature fires.
  3. Backwoods Savage
    That depends upon the stove and the fuel.
  4. JD Guy
    JD Guy
    Upstate SC
    Same here with our Jotul 500.
  5. JD Guy
    JD Guy
    Upstate SC
    On the subject of clean glass….We use a product called”Dirtex” to clean our JOTUL. Have used it for 28 years and glass still looks as good as when new. It’s easy and works well without a lot of scrubbing. And no I don’t have any financial incentive to recommend it:rofl: :lol:
  6. brenndatomu
    More draft when it's colder...
  7. Locust Post
    I was going to say the same thing
  8. Highbeam
    Highbeam
    I agree. That lets the intake air blast harder against the glass for a more effective air wash.
  9. stoveliker
    stoveliker
    Eastern Long Island
    Wouldn't more draft lead to higher flue temps? He says he has the same temp.
    I suggest wood species and little variation in dryness may play a role too.
  10. brenndatomu
    I wonder if it's a one time setting, or come back n tweak a time or two later on? On colder days with drier air I'd think it possible that things could "creep up" after the initial usual setting.
    I my mind that's really about the only thing it could be (draft related)
  11. Highbeam
    Highbeam
    I expect a lower intake setting to get the same flue temp despite the higher draft. In my mind, that would be like forming your lips into a whistle shape to blast the same amount of air harder. That harder blast, like a whistle, directed right at the window where otherwise it would lazily drift into the firebox.
    Maybe I'm crazy though.
  12. ginger1313
    ginger1313
    Same. Ideal steel glass stays crystal clear in the cold months.
  13. billb3
    Your chimney sucks.
    More when it is colder.
    CNE deer, metalcuttr, Ron T and 4 others like this.
