Repairable?
Discussion in 'Everything Else (off topic)' started by Eggshooterist, Jan 14, 2026.
  1. Eggshooterist
    Eggshooterist
    Erff
    Are there any welders / machinests on here that can tell me if this is repairable before I bother trying to find someone locally that think they can? Its a discontinued, Holland Michigan made Yost vise that was $465 twenty five years ago. I got stupid with a cheater on the handle. I tried to get a replacement handle from Eastwood out of Pennsylvania, the company that bought Yost, but they are no longer available. 20260113_100012.jpg 20260113_100036.jpg 20260113_100008.jpg 20260113_100045.jpg
  2. lukem
    I don't know if that's repairable or not, but a machine shop should be able to turn down a new one. Even if you could dowel and weld it up, it's still going to need rethreaded on the lathe. At that point you might as well just have a new one made.
    John D, T.Jeff Veal, Stinny and 8 others like this.
  3. Eric Wanderweg
    Personally I wouldn't want to weld repair that. Too many load/unload cycles might make it fail depending on the alloy its made of. You can buy acme threaded rod from McMaster Carr and cut it to the appropriate length. That would be much preferred to threading a piece of round bar stock. What machining needs to be done to the ends?
  4. Eggshooterist
    Eggshooterist
    Erff
    That's what I was thinking, or buy acme rod and have the handle put on.
  5. Eggshooterist
    Eggshooterist
    Erff
    If it was a new acme rod, it would only need the fat end drilled out and the acme thread rod welded in. The original looks to be all one piece. Machining would be needed if cutting threads through a repair. It looks hardened to some extent. Maybe case hardened.
  6. Eric Wanderweg
    Doesn't sound like much of an undertaking then. It's definitely worth fixing too!
  7. Eggshooterist
    Eggshooterist
    Erff
    I've been without that vise since before Christmas as I was getting the run around from Eastwood until they finally told me the part was discontinued. I had to resort to this yesterday to file rakers. Lol
  8. Eggshooterist
    Eggshooterist
    Erff
    I agree. They started making the new ones in China a few years ago, then Eastwood purchased them. No idea what's going on whith them now.
  9. Eggshooterist
    Eggshooterist
    Erff
    I need to put calipers on that screw to find exact diameter. Then hit the internet.
  10. Backwoods Savage
    Get hold of Kevin. He would probably know.
  11. Eggshooterist
    Eggshooterist
    Erff
    I have a buddy locally with a machine shop thats going to tackle it once his flu is gone.
  12. brenndatomu
    That's right up Screwloose's alley.
    Personally, I'd think having a new one machined would be the best.
  13. Screwloose
    Just buying some rod and put the handle back on it is the easiest. Although a lot of acme rod is cut from 12L14 or other free machining steel that doesn't weld very well.
    Preferably rolled from something with a bit of carbon.
    You can send it to me and I can copy it from a solid bar although I will have to cut the thread. Rolling the thread adds a bit of work hardening for wear resistance.
  14. Eggshooterist
    Eggshooterist
    Erff
    I might take you up on that. I appreciate the offer. Once my buddy looks it over and decides if or what he will do, I'll report back here.
  15. buzz-saw
    buzz-saw
    Ct.
    You beat me , LOL
    I was going to offer my services as well.. if I am needed let me know.
  16. Screwloose
    You might be able to do up a better replacement in your space age shop.
  17. buzz-saw
    buzz-saw
    Ct.
    LOL Not my shop ; I am just the shop-keeper , but this does come with benefits.
    My shop/garage at home , well that's a different story. It looks like an oversized storage unit right now.
  18. RCBS
  19. Screwloose
  20. eatonpcat
