A decent load of mostly ash today
Discussion in 'The Wood Pile' started by Horkn, Dec 31, 2025.
  1. Horkn
    That's not possible with this kit apparently.
  2. brenndatomu
    Now that's confidence in your work!
  3. Woodtroll
    Woodtroll
    Mtns of SW VA
    Did you ever figure out exactly what cutter you were using? Lots of tools work okay to rip panels, even the score and snap method someone already mentioned, but getting a clean cut to cut length across the ridges is a real challenge.
    My ancient Wiss shears, like these, do better than anything else I've used, but I would like to have something a little better/cleaner:
    John D, T.Jeff Veal, Horkn and 5 others like this.
  4. buZZsaw BRAD
    X2. Good trick to remember.
  5. Horkn
    This is what he ordered. It's not here yet. Resized_Screenshot_20260104-144754_TikTok.jpeg
    That said, the boat is in the garage and the garage is complete enough to keep it dry. More snow and rain is coming tomorrow night and this weekend.
    Once the tool(s) arrive, we'll get that bottom 2-3 ft done. I'll keep you updated with the results of the tools
    I'm pretty damm happy at the progress.
  6. Horkn
    Idk if it's a good trick. If it works, great. If not it's an expensive mistake.
  7. Woodtroll
    Woodtroll
    Mtns of SW VA
    Thanks! Looking good so far!
  8. T.Jeff Veal
    Nice work all around. Good wood hoarding and carport building.
  9. Horkn
    It's nice to not have to worry about my boat being not under a roof for the first time this winter. It takes a big weight off of my shoulders.
    Now I just need to get the mtd log splitter throttle linkage back to usable again. I got it to start and run again after cleaning the bowl out, but it didn't want to do anything more than idle. I ran out of daylight the other day after work. Now it's pretty cold out. I might need to bring it out the garage to work on it where is not quite as cold and I can get a heater on me.
