New Saw: Stihl 026
Discussion in 'Chainsaws and Power Equipment' started by Skier76, Dec 24, 2025.
  1. Skier76
    Skier76
    CT and SoVT
    So I’ve been kicking around getting a second saw for awhile now. I have an MS250 that I picked up new about 16 years ago. It’s been a wonderful saw, I could just use more power at some times.
    I saw this 026 on Marketplace for $180. It had been up for weeks as well. Seemed like it was priced lower than the other ones in the area. I took a ride over today, met up with the seller(he showed up a bit late) and went to start it. Unfortunately, it flooded out. Long story short, pulling the plug, pulling it over and reinstalling the plug got it running. Ran good, offered $150 and we settled on $160.
    Got it home, fired it up and went after this Ash that fell on the fence. (Yep! Another Ash on the fence! Luckily, no damage to the fence.) This saw rips! Holds a good steady RPM, less bogging than the 250 in the bigger rounds. It’s also really light! Feels the same as the MS250. Overall, I’m really happy. Felt it was a good score for the price.
    Two small issues to take care of:
    It will die on occasion when idling. Guess this is a common 026 issue. I’ll add Seafoam to the tank and see if that helps before adjust the carb.
    Strong gas smell when off and sitting. I’ll give the lines a check.
    Pics below! (Sorry for the quality, had to resize for the forum software.
    Welcome any feedback you all have.
  2. buZZsaw BRAD
    026 is a great saw. I used one exclusively from 1993 to 2010. Still have it as a matter of fact. The 261 is what it evolved into so its a pro level saw.
    From the looks of it the hours are on the lower side if that's the original bar. Hope it treats you well.
    Bought mine from Yalesville Lawn & Garden center as a Christmas present to myself in 1992!
    brenndatomu, eatonpcat, RCBS and 14 others like this.
  3. Canadian border VT
    Nice 50 cc there you got a deal
  4. Duane(Pa)
    Duane(Pa)
    Centre Co.
    Tank vent is probably leaking. They had about 3 different types over the years. Good score.
  5. The Wood Wolverine
    You got that for a great deal IMO. :thumbs:
    Getting a used saw with unknown maintenance history, I’d plan to put a carb rebuild kit on the list, also new fuel line and both gas & air filters. Cheap and easy to do.
  6. Skier76
    Skier76
    CT and SoVT
    Thanks guys! I’ll take a look at the tank vent. Hopefully and easy replacement. Seller said he did lines and a fuel filter. I’ll have to give it a close once over.
    brenndatomu, Chaz, eatonpcat and 10 others like this.
  7. Skier76
    Skier76
    CT and SoVT
    Ok, here’s the vent. Oddly, it didn’t smell too much today. But certainly something I want to address.
  8. Duane(Pa)
    Duane(Pa)
    Centre Co.
    That style pulls straight up and off. I was able to rig an Echo vent on and it didn’t leak. There is a nipple underneath that black thing. I put a stub of fuel hose on the Echo vent and forced it into the bore of nipple. (not outside as most conventional hose connections). Presto! They made about nine quadrillion of those, so not really worried about originality. I know of people who will suffer with a fuel leak to stay original. I’m not that guy
  9. T.Jeff Veal
    Yes, good deal on that saw. Now get it on huskihl list for some Xtra Sausage...you will be amazed.
  10. Canadian border VT
    ^^ this is better idea then he realizes
  11. Skier76
    Skier76
    CT and SoVT
    Thanks guys! I’ll pull the vent off and have a closer look. I really need to pull the covers off and give everything a good once over.
  12. Duane(Pa)
    Duane(Pa)
    Centre Co.
    Most, if not all, have a pretty restrictive muffler. Pretty easy to rectify without much effort.
  13. WeldrDave
    Great deal on the 026! :cool: I found an older 028 with very similar circumstances! Mine was "old gas" and a missing fuel vent. o_O
  14. Skier76
    Skier76
    CT and SoVT
    Had a little time today to dig into the saw. Over all, seems to be in really good shape.
    Some pics:
    So the vent is the source of the leak. I tipped the saw on its side and saw the leak. Duane(Pa) What are the specs for the hose/line you used? Also, which Echo vent did you use? That route makes sense to me.
    OEM breather
    Random note: These battery powered blowers are awesome. If you don’t feel like charging up the compressor, they really move some air! The tip I have here worked well. There are others to choose from that come with it.
    Couple shots of it all cleaned up and next to the MS250.
    Pulled the muffler and had a look at the piston. Sorry for the quality here as my phone focused on the inside of the muffler and not the piston. It was in really good shape; no scoring at all.
  15. Duane(Pa)
    Duane(Pa)
    Centre Co.
    C241ABF3-D079-403F-A542-C6CD5FD475D9.jpeg I just messed around with different diameters and length tygon hose looking for a force fit that would not vibrate loose. 69F27633-CC3B-4313-85A4-B41539714019.jpeg
  16. The Wood Wolverine
    I just put one of those Echo vents on my old edition 346xp. They work well. :yes:
  17. Duane(Pa)
    Duane(Pa)
    Centre Co.
    I’m pretty sure huskihl turned me on to these vents. I have them on a bunch of saws. Did I just incriminate myself? I have not tried anything but OEM.
  18. Eggshooterist
    Eggshooterist
    Erff
    He turned me on to them as well. For use outside of echo products that is.
  19. Skier76
    Skier76
    CT and SoVT
    Awesome! Thanks guys! Seems like a really easy fit. Anyone know what diameter line you used for this?
  20. Duane(Pa)
    Duane(Pa)
    Centre Co.
    Wish I could be more specific. Find something that is snug in the bore. That is important. The vent has a barb shape that will squeeze into different size hose.
