Worn drive gear
Discussion in 'Chainsaws and Power Equipment' started by Paul Dokken, Dec 7, 2025.
Tags:
  1. Paul Dokken
    Paul Dokken
    Waxhaw NC
    Anybody know what would cause the chain to wear through the gear like this?
  2. The Wood Wolverine
    Improper tension will cause premature wear there. That looks pretty extreme. Sure you have the proper pitch chain?
  3. Woodtroll
    Woodtroll
    Mtns of SW VA
    How many chains has your saw been through on this sprocket? They are considered a wear item. Oregon suggests replacing the sprocket every two chains. I usually get more out of them than that, but it's a place to start, I guess. If you feel it's premature wear, Wood Wolverine made good suggestions.
    John D, metalcuttr, Horkn and 7 others like this.
  4. Chud
    Chud
    Over the years I have encountered some folks that think if they tension the chain super tight it won’t get slack. Instead of sharpening the chain they tighten the chain and continue. I have never seen a spur sprocket as hammered as yours. Wow
    MikeInMa, John D, metalcuttr and 6 others like this.
  5. Paul Dokken
    Paul Dokken
    Waxhaw NC
    I'm sure I have the proper pitch. I probably ran about 80 tanks for gas through the saw. I didn't think I had the chain too tight or too loose.
    MikeInMa, metalcuttr, Horkn and 4 others like this.
  6. Screwloose
    80 tanks explains a lot! It is a consumable part and gave you good service. Maybe get a new one with a rim sprocket.
    I'd say that it's a wall hanger for sure.
  7. The Wood Wolverine
    Imagine what the drive links on the chain look like. :eek:
    MikeInMa, metalcuttr, Horkn and 5 others like this.
  8. RCBS
    That... is completely knackered. I'm sortof impressed. 'I paid for the whole sprocket, imma use the whole sprocket!' :thumbs:
  9. Eric Wanderweg
    I’ve got a small collection of clapped out spur gears that have tons of hours on them. They don’t look like that. Slow wear through excessive use produces a smooth narrow groove where the drive links were tracking. All that displaced metal that turned blue tells me it happened rapidly. When you say you verified the chain pitch, you mean that you measured the distance between one pin and another 2 pins away, and took that number and divided it by two? And then confirmed that the bar you’re running is that pitch by locating the factory stamping/etching? What I’m getting at is that I’ve been burned years ago simply going into a store, picking up a package of chain, looking at the back, seeing my model listed and thinking it’s the right one. Many models have different bar and chain combinations. Pitch, gauge, low profile chain as opposed to standard. Lots of variations.
    The whole spline on yours is blue from overheating. I suppose that could happen if the sprocket finally reached a tipping point and the chain suddenly started slipping, but I would think you’d feel that in the performance and stop before it got out of hand.
    MikeInMa, metalcuttr, Horkn and 6 others like this.
  10. Paul Dokken
    Paul Dokken
    Waxhaw NC
    What is a rim sprocket? I am using 20" .325" pitch 80 links .050 gauge chains
    metalcuttr, Horkn, eatonpcat and 3 others like this.
  11. MAF143
    MAF143
    North Central OH
    different type of sprocket and clutch drum that is found on most pro series saws. I put them on even my home owner grade saws.
    You have to get one that fits your saw, but they will last longer and allows the chain to float better on the sprocket and not bind going into the bar groove. You can also get different drive count sprockets if you have torque you want to trade for chain speed, like a short bar on a big ported power head.
    metalcuttr, Horkn, RCBS and 4 others like this.
  12. Paul Dokken
    Paul Dokken
    Waxhaw NC
    John D, metalcuttr, eatonpcat and 3 others like this.
  13. ironpony
    ironpony
    Mid Ohio
    Well it is not April 1st so, looks like soft metal to me but if it made it 80 tanks of fuel...........................I would say it owes you nothing and replace it
  14. Screwloose
    If your saw is listed you should be good to go.
  15. The Wood Wolverine
    As long as it matches the pitch of your bar tip sprocket.
    metalcuttr, Horkn, eatonpcat and 2 others like this.
  16. Paul Dokken
    Paul Dokken
    Waxhaw NC
    I did replace it so it is not the original with one from Amazon. Maybe bad metal?
    John D, Screwloose, eatonpcat and 2 others like this.
  17. John D
    John D
    Syracuse ny
    That is definitely a possibility
    eatonpcat and Screwloose like this.
  18. John D
    John D
    Syracuse ny
    If this fits your saw I would say this would be the best option
