Electric motor questions
Discussion in 'The DIY Room' started by Stephiedoll, Dec 7, 2025.
  1. Stephiedoll
    Stephiedoll
    Omaha, NE.
    My mom has a gas barrel at the house, something dad put in over 50-years ago. The switch decided to go bad so now we have to "play with it" it get it to work. Wondering what kind of headache it is to pull the side of the motor off that has the switch to either clean it or bypass it and put an external switch on it. 20251206_135558.jpg 20251206_135601.jpg 20251206_135605.jpg 20251206_135619.jpg
    John D, RCBS, metalcuttr and 4 others like this.
  2. wood and coal burner
    Quakertown,PA
    Only concern I would have is a pump motor or switch for any flammable or combustible should probably be explosion proof construction.
  3. MAF143
    MAF143
    North Central OH
    X2
    I just fixed my 40 year old table saw motor last week. It however, was not anywhere near flammable stuff. Normally cleaning, greasing the bearings, and touching up contact surfaces inside the motor will get most running again. Mine had the internal centrifugal switch contacts with crud on them. Cleaned them with sandpaper and put it all back together and it works like new again. That switch has to be closed to allow the motor to start, but opens as soon as it gets up to a certain rpm.
    I've never worked on explosion proof gear so I'm not sure what it takes to make them sealed up to keep gas fumes, oxygen, and sparks all separated. Switches for sure make sparks...
    Stay Safe!!!
  4. brenndatomu
    Many/most times explosion proof motors aren't actually totally sealed...they are just made in a way to contain an explosion/flame path.
    I would think that a gas pump would surely be a class 1/div 1 designation, which means it's designed to be used around explosive fumes.
    Most of the time it's really not that hard to work on them, but I have zero experience with a pump like that one, and no idea how hard it will be to get into, or find parts for.
    You could likely find a new switch that would work, but technically the only way for it to still have its class 1/div 1 designation, it has to be worked on by a certified repair center...but lawyers are the main people that really care about that. Some motor shops will still repair a model/brand that they are not certified to repair, if you sign off on their liability.
    That said, I'd totally try to tear into that if it were mine, but that's just me.
  5. Screwloose
    Is the barrel gas or diesel? The end of the motor with the switch will come off.
    Clean the end so you don't get dirt in the mating surfaces. As Dave said they are not air tight but use close fitting joints to stop flame spread. It probably has a standard switch inside although you might find it is a linkage issue.
    Carful when you pull off the end as the wiring is usually rather short.
  6. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Thanks all, I didn't think about the explosion proof until last night/this morning. One option in the back of my mind is to bypass it and let her use the circuit breaker that is just inside the garage door, but that's not my first choice. Good chance we can get an electrician if needed but at least for now it is working and mom did use it by herself yesterday while we were there.
    Edit to add, that we could also install a switch on the side of the house for her to use.
  7. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Gasoline just thought I should get some ideas first plus we only had a couple of hours to spend up there. Next trip I will take the air compressor plus plan on the weekend, hopefully above freezing, to see about taking it apart. I will also be running these ideas past my brother who helps with these projects.
    Looked at replacements, around $500 range, but I bet this one will outlive them.
  8. brenndatomu
    So it sounds like you can get it to work if you play with the switch long enough...so do that, get it to run, then just leave it on at the pump, after you wire a power switch inside...that's how Dad has his, just for theft reasons.
  9. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Correct, seems like when you pull it all the way out and then push it back in halfway is working so gives us time to get back up there (Christmas) and hopefully have nice weather.
    Thanks again.
    Screwloose, brenndatomu and MAF143 like this.
  10. Woodwidow
    Okay. I have to ask. What is a gas barrel and what does it do? Provide heating?
    Screwloose, brenndatomu and wildwest like this.
  11. wildwest
    Me too
    Screwloose and brenndatomu like this.
  12. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Basically, a farm gas tank, but in town. My dad always kept if for his personal as well as shop vehicles. He passed away but our mom still uses it to fill her cars with gas. Saves her from going downtown to a station to fill up. My dad always filled it when prices were down but went downtown if the prices dropped below what he paid for bulk gas.
    Woodwidow, Screwloose, RCBS and 3 others like this.
  13. brenndatomu
    I don't think bulk tanks like that are allowed in town around here
    Screwloose, eatonpcat and RCBS like this.
  14. RCBS
    A lot of this. I don't recognize that brand. My work deals in FillRite which used to be better known as GasBoy. I think some of that stuff is proprietary due to the hazard risk.
  15. RCBS
    Still OK here. Legal version calls for a pad and catch. Zero enforcement untill you have a boo boo.
  16. MAF143
    MAF143
    North Central OH
    My Grandpa had a hand pump one. One turn of the handle equaled one gallon of gas. His brother, Great Uncle Paul, had a gravity fed tank up on an overhead stand. They ended up getting rid of those tanks as my older cousins got cars and started to drive!!!
  17. brenndatomu
    Holy cow...we have a hand crank one at work and I think its 10 turns/gallon!
  18. MAF143
    MAF143
    North Central OH
    I don't remember exactly how it worked, it may have been less than a gallon, but the crank handle was about a foot long and was hard to turn. You turned it one way and it filled up a large cylinder part on the pump and then you turned it the other way to get it to come out the hose into the tractor. It was a long time ago and they got rid of them when I was a little kid. I looked for some pix of one like he had but didn't really see anything that hit me as spot on. I'll ask some of my older cousins if they remember.
  19. MAF143
    MAF143
    North Central OH
    I talked to my cousin duck and he remembers it well. Grandpa's worked with one turn to pull up about a half gallon or so into the cylinder of the pump. Then the handle went back the other direction to push that out the hose into the tractor.
    Kinda looked like this.
  20. brenndatomu
    Cool, never seen one like that!
