Can anyone ID this insert?
Discussion in 'Modern EPA Stoves and Fireplaces' started by williaty, Dec 5, 2025.
  1. williaty
    williaty
    Knox County, Ohio
    New house, new stove questions.
    One room has a masonry fireplace that's been converted with a wood stove insert. The small label in the corner says Pacific Energy. Can anyone ID the model so I can get a manual for it? Anyone know if it happens to be any good or if there's anything I need to know about it (only prior experience is with an Ideal Steel, for reference).
  2. Jeffrey Svoboda
    Jeffrey Svoboda
    Have you contacted Pacific Energy?
  3. williaty
    williaty
    Knox County, Ohio
    Sent an email with the same photo. Radio silence for a couple of days now. It's not too surprising since it's the holiday season. Thought maybe you guys would have a quicker answer for me.
  4. Warner
    Good looking set up! Have you had the surround off? Any chance you can see the tag? If not it might be a good time to check out the install, how the liner is connected and all that fun stuff.
    brenndatomu and wildwest like this.
  5. Jeffrey Svoboda
    Jeffrey Svoboda
    Iirr, brenndatomu is pretty knowledgeable with different stoves. If he doesn't know maybe he can remember someone who would.
  6. Burnin Since 1991
    Burnin Since 1991
    Probably fastest way is to look on the sides and bottom of the unit for the tag. By far the easiest
    wildwest and brenndatomu like this.
  7. brenndatomu
    That looks like it might be a PE Alderlea T5 insert LE?
    I can't speak for that model, but PE doesn't make junk...I would say it's above average stuff.
  8. williaty
    williaty
    Knox County, Ohio
    Without a manual, I have no idea how to get the surround off of it to be able to look for a tag.
  9. williaty
    williaty
    Knox County, Ohio
    I checked a picture of that model and what I have doesn't have the ornamentation that the Alderlea does.
  10. williaty
    williaty
    Knox County, Ohio
    I haven't gotten the surround off. That's one of the things I want to learn how to do from the manual. Before I light it up, I'll be having someone come out to inspect everything.
    Warner, brenndatomu and wildwest like this.
  11. buZZsaw BRAD
    Looks very similar to the "Summit" model I had in my house that I sold in 2010.
    I bought it in 2001 and had zero complaints about it.
  12. wildwest
    Wow, it sure does, even the air control lever.
    Summit Insert LE
    buZZsaw BRAD and brenndatomu like this.
  13. Locust Post
  14. blacktail
    blacktail
    PNW
    Either a PE summit or PE super.
