Shield for my stove for safety
Discussion in 'Modern EPA Stoves and Fireplaces' started by cezar, Dec 3, 2025.
  1. cezar
    cezar
    KY
    My kid decided to test out the glass on our stove last night. Fortunately it was near a reload and the glass he touched with both hands was only 260F compared to the 800F or so I have measured it at when it's at full chooch.
    He'll be fine thankfully. And I am confident he'll never test it again. But I'm concerned about the possibility of him (or anyone!) tripping and faceplanting into the glass. The stove body itself never really gets beyond 300F or so, but 800F on the glass seems like lifelong injury territory.
    I think my Clydesdale is one of the largest glass fronts on the market and there is a lot of real estate for that glass that gets absolutely ripping hot. Any thoughts on things I can do to prevent the possibility of someone accidentally tripping and making contact? My living room is on the small side so there will always be kids and adults and dogs walking nearby all winter long.
    I can get one of those 3-panel guards and that will probably work but it's a gigantic eyesore and also inconvenient. Wondering what others have done in this situation.
  2. Burnin Since 1991
    Burnin Since 1991
    [​IMG]I use the fireplace screen. My son has a pellet stove insert and he uses the kiddie fences? These are similar only not made out of plastic
    Amazon.com : Baby Playards
  3. cezar
    cezar
    KY
    I'm _specifically_ worried about the 800F glass face. I am not ideally looking to babyproof the stove body itself, just the glass alone due to the insane temperatures it reaches. My IR gun goes to 850 and I've had it do "--" a couple times. It probably gets into the Leidenfrost effect at those temps and you would just bounce off it, but there is obviously some range where it's truly dangerous for anyone that would trip into it.
    I'm surprised there isn't some sort of double-glazing on these things that ties into the blower to channel air up and out...
  4. Burnin Since 1991
    Burnin Since 1991
    Sorry, I don't know of anything like that. Interested to see if you come up with something
  5. wildwest
    I didn't risk it, previous home had a custom wood enclosure with door. Here, only 2 woodstoves for heat, both of them got plastic panels around them. Since then we used them camping to contain the two dogs and more recently for blocking chickens lol.
    Only issue we had, but smelled it quickly, was when she tossing her security blanket in the air and it landed on a stove. Looked like a burn from a clothes iron forgot on shirt lol.
  6. wildwest
  7. MikeInMa
    We have a tri-fold screen the gets setup when kids or animals are visiting. It folds up and is stored behind the woodstovevwhen not needed.
    Even with space a consideration, why protect just the glass? Protect the entire stove, imo.
  8. Backwoods Savage
    I grew up knowing only wood heat. Most of you know what kind of stove we had back then (1940's). There were 4 of us kids and I don't recall ever having a disaster with the stoves (2 heating and 1 cooking stove). Yes, occasionally someone might get a burn while loading or emptying ashes but nothing serious.
    But here is something everyone should know. If you or someone else gets burned, immediately put liquid vitamin E on it. It works and I've never seen anything better.
    So far this year I've had only one slip and accidentally touched the firebox door. Vit E to the rescue. No blister and not even a red spot. I could tell many stories but perhaps one stands out more than the others. One time we were in Alaska and it was cold! We were sleeping in a tent and no heat. In the morning I started a nice fire outdoors and wife made coffee. When coffee was ready she brought it to the campfire and sat it on a couple sticks so it got heat from the fire. The danged thing got tipped over right away and got her one foot. OMG! I rushed inside and plastered that reddened foot with the E. She wore a loose slipper that day. The next day she wore her shoe. All was well but we feared it wouldn't be because the coffee was so hot and the foor was beet red when it happened. Thankfully this turned out well.
  9. Pyromaniac
    Pyromaniac
    Central Michigan
    New grandson this year, almost one year old now. We raised two with a wood stove and like others here, don't remember one time either got burned. This year, however, I welded up some rerod to make an enclosure with fencing. Just didn't want to risk it. Only takes me two minutes to assemble/disassemble. For the two or three days a week we have him, well worth it. Hard to believe, I still ride a bike without a helmet.
  10. brenndatomu
    Thanks for the reminder, I had forgot about that.
    You think E is better than aloe right from the plant?
  11. cezar
    cezar
    KY
    Well in an absence of better ideas I ordered one of those tempered glass panels.
    The vitamin E tip is great tho, gonna order some.
  12. Pyromaniac
    Pyromaniac
    Central Michigan
    Can you provide a link or brand/make of what you ordered? May help others in the future with the same problem.
  13. Backwoods Savage
    We've used both in the past but always had better results with E.
    Aloe works better on old burns, like if someone was unable to treat the wound then I think aloe is best on old wounds or skin problems.
  14. Eggshooterist
    Eggshooterist
    Erff
    I think that's a fantastic idea. We'd do that exact thing if we had little ones or animals to protect from burns.
  15. cezar
    cezar
    KY
    I ordered this guy:
    It comes Monday. I can already tell I'm going to have some struggles with it. Number one, how am I supposed to adjust the air control when this is in the way?
    Best I can come up with is maybe I'll run some angle iron under the stove and put it on some sort of a hinge? IDK. Not vibing with it.
    Maybe I can get a piece of glass cut to size and just stick magnets on it and it can just stick onto the front glass surround? Seems like a better solution. I'm a little annoyed that I have a 900F piece of glass at knee level in my living room tbh...........
    EDIT: Sorry, but this forum deletes amazon links...
  16. MikeInMa
    Screenshot the page/image and upload the pic
  17. Jeffrey Svoboda
    Jeffrey Svoboda
    Take out the https and maybe even the :// then it should post the link.
  18. cezar
    cezar
    KY
    Here: <amzn> /dp/B0FMXXJ5C9
    metalcuttr and brenndatomu like this.
  19. Jeffrey Svoboda
    Jeffrey Svoboda
  20. Pyromaniac
    Pyromaniac
    Central Michigan
    Just looked at that item on Amazon. Hard to believe this won't get blazing hot as well if fitted directly over the glass on the door. Don't think I would want a child touching that at full burn either.
