Splitting Tires
Discussion in 'Axes, Mauls, and Hand Saws' started by Cold Trigger Finger, Nov 13, 2025.
  1. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    Yup.
    If your wood is small enough diameter to fit inside an old tire u have laying around . I set the tire on a big enough round so the block I'm splitting has firm support. Then wail away . It also works great for stuffing it full of smaller rounds . Then wack wack wack split those too . Really saves chasing splits and chunks all around the woodyard.
    walt, EODMSgt, RichE23ACR and 9 others like this.
  2. arizonasportsman
    arizonasportsman
    Prescott, AZ
    Like the measurements on your ax handle. :yes:
  3. Jeffrey Svoboda
    Jeffrey Svoboda
    I've screwed the bead down to the chopping block underneath. Keeps the tire from sliding off.
    Definitely a back saver not having to pick up splits just to replit and pick up again.
    EODMSgt, RichE23ACR, MikeInMa and 5 others like this.
  4. Cold Trigger Finger
    Cold Trigger Finger
    Exactly!!!!
    On rounds that are too big to fit inside the tire . I will split them in quarters , set 2 quarter s in at a time and split them . Usually can put in 2 quarters but not 1 half round .
  5. Cold Trigger Finger
    Cold Trigger Finger
    When actually Chopping wood , = fall , bucksplit and limb with axes only . The measurements on the handle are quite handy. With the Bucksplit method its easier to run more consistent lengths . Bucksplit works best in deciduous species . Hard to do in conifers due to the limb structure . . Since being on our place here . I've burned around 5 cord of Aspen and Birch that I chopped on my property. Most of it in the winter . Most of it bucksplit.
