A simple wood shed for a friend
Discussion in 'The DIY Room' started by T.Jeff Veal, Oct 1, 2025.
  1. T.Jeff Veal
    We did some brush mowing for a lady this spring. While we were there, we noticed she had a very big pile of split oak from a tree she had taken down. She said she didn't have anywhere to store it. I showed her some pictures and said we could build her a small shed. We built it Monday morning.
    Initial spot was going to be behind where it is, next to the fence line, but with the grade and unhappy fire ants, we decided to choose another location.
    End pallets are set where notch is flush with bottom edge... 20250929_110653.jpg
    Ends are now set...the floor is 2 44x52 and 1 36x52 pallets. Ends are 44x52 pallets.
    Tried something new on this shed, we added a 2x4 to the 2x6 uprights. 20250929_113343.jpg
    The uprights are screwed into the 4x4's and both bottom and end pallets 20250929_113804.jpg
    She wanted a small section to store her kindling can and bucket. Added another pallet and upright supports 20250929_124423.jpg
    She had several sheets of metal roofing that was 63" long, just did a good overlap and used 6 pieces to cover the roof... 20250929_142654.jpg
    We set her chopping block in a new hole close to the shed... 20250929_143904.jpg
    We told her to get some diesel and ATF fluid and paint/spray bottom boards to help prevent rot.
    She had about $230 dollars in lumber and supplies. We had a 6' piece of 2x4 left over.
  2. Eric Wanderweg
    Looks great and no doubt she appreciates having it :thumbs:
  3. The Wood Wolverine
  4. SimonHS
    SimonHS
    Yorkshire, England
    Great work! I love that chopping block. Looks to have seen some action over the last few years.
  5. T.Jeff Veal
    Yes sir, she had used it a good bit.
  6. wiguy
    wiguy
    Wisconsin
    Very nice!! I don’t really have a wood shed, probably could use one, but I have a system. It starts with basically moving some wood into the garage on nice weather days, comes in mostly dry. In the height of the main winter, I’ll throw an old trampoline mat over the part of the pile I’m using, keeps the snow off.
    Then I like to fill the wood box near the stove when the fire is going well. Any wood brought in gets at least a few hours to dry out more.
    That all said, I do appreciate a wood shed to keep moisture off.
  7. ReelFaster
    ReelFaster
    S.Jersey
    Great job, looks awesome!
  8. sms4life
    sms4life
    Love woodshed builds. That is simple and functional.
    I can't tell from the pictures, but what are the 2x4 on the uprights used for?
  9. T.Jeff Veal
    Strength/rigidity, we have built some for ourselves without the 2x4's, over time with a big load of wood, the 2x6's will bow out, since the weight is against the narrow side.
  10. sms4life
    sms4life
    Got it. Good idea.
  11. Jeffrey Svoboda
    Jeffrey Svoboda
    Looks good. How do you get away with no diagonals from the roof to the walls or floor to the walls?
  12. MNWood
    MNWood
    Coon Rapids Minnesota
    I work for a paint and sundries company, manufacturing and retail. I can get damaged cans of deck stain free. That is what I would use on those boards but I'm curious how the diesel and ATF mix perform in comparison.
  13. T.Jeff Veal
    When empty, it can be a little shaky sometimes, but loaded, it's very rigid. This shed is the sturdiest we've built. If needed, corner braces could go from roof to sides, at the floor would be in the way of stacking wood
  14. T.Jeff Veal
    Probably better than stain, remember how good oil based paint lasted outside? Petroleum base products last well in the weather. We had a trailer we sawed red oak decking boards for, we let it dry for about 6-7 months on the trailer, that July-August, we started painting it with used oil/diesel mix. We put several coats on it. It sat outside year-round, 25 yrs later floor was still solid.
  15. T.Jeff Veal
    These sheds we built are 10 yrs old now... IMG_20180616_175953.jpg IMG_20151203_162439323.jpg
    Bottom pallets are still in good shape, nothing was ever put on them.
    I suggested treating hers, because of the run-off from adjacent roof splashing on it.
  16. Jeffrey Svoboda
    Jeffrey Svoboda
    That makes sense. The 4000+ pounds loaded in the shed didn't even cross my mind.
    Yeah it was an either or type thing.
  17. yooperdave
  18. buZZsaw BRAD
    Simple and effective. Well done Jeff (and Ms. Carol if she helped) :thumbs:
  19. T.Jeff Veal
    Yes sir, she most always does
  20. Yawner
    Yawner
    Louisiana
    That is awesome, I so admire building skills! If you come back, Jeff, do you get your pallets from work? What wood do you think they are made of? What wood do you think her chopping block is? Does this lady chop her own wood? Or maybe she is a customer!
    Wish I had a shed like that. Or three. Wonder how much that one will hold.
