What did I score?
Discussion in 'The Wood Pile' started by CutSplitStack, Oct 31, 2025.
  1. CutSplitStack
    CutSplitStack
    Grabbed a couple of sticks of this stuff, cuttings from the power company. There's tons more of it, any ideas on species?
    RCBS, Dakota Hoarder, jrider and 12 others like this.
  2. Eric Wanderweg
    Black locust, excellent grab!
    RCBS, Dakota Hoarder, jrider and 10 others like this.
  3. jo191145
    Grab all you can and provide pictures. You’re close to hero status, don’t mess this up :)
  4. buZZsaw BRAD
    Looks like black locust, but the leaves don't. Are the leaves in the pics from the same logs CutSplitStack ? Buck a bigger round and split it. BL should split clean, elm will be stringy.
    If it is indeed BL you done good. Id be camping out by it until it's home.
  5. buZZsaw BRAD
    Im not 100% convinced its BL. Could it be red elm?
  6. Eric Wanderweg
    Good catch. It’s Siberian elm. Small leaves.
  7. John D
    John D
    Syracuse ny
    X2 this is what I came up with
  8. The Wood Wolverine
    From BL to elm, hero to zero? :faint:
  9. Locust Post
    It'll burn !!!
    jo191145, John D, eatonpcat and 6 others like this.
  10. CutSplitStack
    CutSplitStack
    Haha, thanks everyone. I figured I'd get some excitement out of this! Yep, it is Siberian Elm, the crew cutting for the power company ID'd it when they were dropping it. But there is a bunch, and it does seem to split very easily. So decent BTUs and runs thru the SuperSplit no problem, I think I'll be grabbing a few trailer loads. No need for the hero label, but definitely not a zero score!
  11. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    No Elm that I’ve ever seen splits very easy!!
    I thought it looked like highly valuably black walnut!
    jo191145, John D, theburtman and 4 others like this.
  12. Wouldsplitter
    Wouldsplitter
    Illinois
    The best way to process elm is to cut it into rounds and leave it sit for a few months. Then split with the growth rings. Not across the center of the round.
    jo191145, John D, theburtman and 3 others like this.
  13. BuckeyeFootball
    BuckeyeFootball
    Siberian Elm 100% it splits way easier than any other elm. I used to get a bunch of it for how wet it usually is it dries pretty quick. The bark peels off bigger pieces rather easily too.
  14. buZZsaw BRAD
    Without leaves present, is there an easy way to differentiate elm varieties? Not one of the species I'm good at IDing.
    John D, jo191145 and MikeInMa like this.
  15. Wouldsplitter
    Wouldsplitter
    Illinois
    You can peel off a piece of the bark and look at the cross section. If the bark has alternating layers of creamy white and reddish-brown then it's American Elm.
  16. Jeffrey Svoboda
    Jeffrey Svoboda
    That green lichen on the bark in the second pic is a dead give away for Siberian elm around here. Big patches on the trunk bark.
