Never had this happen before
Discussion in 'Chainsaws and Power Equipment' started by Cold Trigger Finger, Oct 30, 2025.
  1. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    20251029_144809.jpg I've had this bar for at least 4 years.
    Never had the slightest Hint this was going to happen . And I had put on a new chain 1/,2 cord before this happened .
    M2theB, John D, RichE23ACR and 17 others like this.
  2. MAF143
    MAF143
    North Central OH
    Not a fan of getting stuck but if you cut wood it's bound to happen at some point. I try to always have a few wedges with me to prevent it before it happens. But I've been out in the woods without them and gotten a surprise pinch or two!!!
    But I've never broken a bar...
    YET!!!
  3. cezar
    cezar
    KY
    Has to be a metallurgy issue.
  4. MAF143
    MAF143
    North Central OH
    Was that mostly composite where it snapped? or was it mostly steel there?
    I have one Stihl lightweight bar and a couple of the TsuMura but I don't have any of the Husqvarna light bars.
  5. RCBS
    Interesting right at the point of the dogs. Sugi makes them. I've only known Sugis to have breakage back by the mount holes thusfar.
  6. The Wood Wolverine
    Pretty certain they are made by Sugihara.
    I have 2 Sugi’s and have for many years. Longest is 20, they’ve been great. I don’t stress bars much though. If they’re stuck I either grab another saw or wedges.
  7. MikeInMa
    Some days you're the windshield. Some days you're the bug.
  8. eatonpcat
    Such a clean break...Strange
  9. The Wood Wolverine
    Right at the end of the dogs too. I’m guessing it gets lateral stress there a bunch.
  10. Screwloose
    Never broken a bar but have worked with hundreds of fractures. Hang it on the wall for sure! Your time to be the bug.
    John D, sms4life, walt and 7 others like this.
  11. Cold Trigger Finger
    Cold Trigger Finger
    Was
    Wasn't stuck . I pulled the remains of the bar out with my hand . I tapped in a wedge to get the chain out as it was a Brand new chain
    John D, MAF143, Screwloose and 8 others like this.
  12. Cold Trigger Finger
    Cold Trigger Finger
    Yup. In the 4 years since I bought it new . I've limbed and bucked probably 75 cord with this bar . I have only once or twice had it hung up . Then it was just tap in a wedge (plastic fallin wedge) a little and out it came . Ya can't make a living cuttin timber if ya get hung up all the time. I haven't really examined it closely since it happened .
    John D, MAF143, metalcuttr and 8 others like this.
  13. Cold Trigger Finger
    Cold Trigger Finger
    I will do my best to remember to post more pics tomorrow when I'm around 5 bars of 5G.
    As I was bucking that fat Birch log , I could feel the cut just starting to close and was bringing the tip out to run it back in . Like I always do as I'm bucking . All the sudden the saw started vibrating violently and making a weird Bad noise i instantly popped the brake and shut it down and realized the powerhead was no longer connected to the whole bar . But , the chain was.
  14. Cold Trigger Finger
    Cold Trigger Finger
    This is a quick pic I snapped before I pulled the bar out of the cut 20251029_144841.jpg
    John D, MAF143, metalcuttr and 9 others like this.
  15. Cold Trigger Finger
    Cold Trigger Finger
    Not too much . Compared to hundreds of other bars that I've had . I haven't done much falling with this bar . Falling timber will put a lot of stress on a bar. And I have bent bars , had bars get twisted lengthwise . Had lots of tips blow , had bars crack through the oiler hole and chain adjuster holes . But never had this happen.
    Looking at the grain of the steel at the break . It looks crystallized. I think it's a manufacturing defect. Over hardened and not annealing. Ie brittle
  16. T.Jeff Veal
    Wow, never seen anything like that.
  17. buZZsaw BRAD
    Holy chit! That's almost unbelievable.
    I pinch bars often enough and may have squished a tip or two, :emb: but never broke one.
    I wonder what Husqvarna would say if you sent pics to them?
  18. The Wood Wolverine
    4yr old bar? Probably nothing.
  19. Cold Trigger Finger
    Cold Trigger Finger
    That was what I was thinking also.
  20. Cold Trigger Finger
    Cold Trigger Finger
    Yes, I have wrecked lots of bars . But never when just making a totally Normal buck like I was .
    Being old , and with a life time of making a living with chainsaws. I don't get hung very often at all . And , I Always have 2, bar wrenches on me , one in the side belt pouch on my chaps . And one in the side tool pocket of my riggin pants .
    If/when I get really hung up . And it's not a situation I can wedge out of. First thing I do is pull the powerhead off. Have to , to put a spare bar and chain on . To fall a driver into the tree I'm hung in or to buck out my stuck b+c .
    Kinda of a , protect the powerhead at all costs kinda thing .
    If the chain is still spinning , most of the time the whole saw can be pulled from the cut without tearing the mounts up . Another reason I run longer bars and do almost all my cutting with the front half of the bar .
