FHC Dictionary.....let's have a little fun, shall we?
Discussion in 'Everything Else (off topic)' started by Scotty Overkill, Oct 22, 2025.
  1. Eric VW
  2. Backwoods Savage
    You need to get out more.
  3. Scotty Overkill
    I'm doing residential trees that end up as firewood 99.9% of the time sooo...humboldts for me!
  4. Backwoods Savage
    Vertical = The best way to operate a log splitter. After all, even God preferred vertical and that is why they grow that way. We should do it (split, that is) vertically too.
  5. Scotty Overkill
    With the legendary milk crate seat!!
  6. Backwoods Savage
    I don't think anyone has mentioned kindling wood.
    How about Pickeroon, hookaroon and peavy. Timberjack.
  7. Scotty Overkill
    "codominant" ("co-dom") - a tree that has two or more main leads either right off of the stump or a ways up the trunk of the tree, featuring steep, tight compartmentalized growth that sometimes can be confused as being one trunk. These trees need to be carefully inspected and assessed when cutting and felling, especially when the co-dom is near ground level. Sometimes the face cut alone can completely sever one of the co-doms away from the other resulting a catastrophic situation. We usually tackle those by going up past the compartmentized growth and taking both leads out separately if the situation allows.
  8. Scotty Overkill
    Write them up with definitions my friend, for those that don't know what they mean.
  9. Scotty Overkill
    "tinder" (not to be confused with the dating app) - fine, dry organic material (usually shredded leaves, grasses, or in our history "noodles") used in a small bundle to ignite the kindling.
    "kindling" - small twigs, slivers of wood, shavings or other organic matter that is used on top of tinder for getting your fire going.
    "noodling" - the act of ripping billets down with a chainsaw along the grain of the wood.
    "noodles" - the long slivers of wood created by the act of ripping billets of wood down with the chainsaw along the grain of the wood. They closely resemble miniature linguini noodles, hence the name....
  10. Eggshooterist
    Eggshooterist
    Erff
    Im sure getting out more wouldn't have answered that question. Lol
  11. Backwoods Savage
    Kindling: usually small pieces of wood used to kindle a fire.
    Pickeroon/hookeroon: A handy tool used for rolling logs, carrying small logs or used as a handy weapon.
    Timberjack: One of the more useless tools one can purchase.
  12. Backwoods Savage
    Saw chaps: An article of clothing to guard against being cut by chainsaw. Also used widely during warm weather as a substitute for a sauna.
    Log splitter: A device for splitting logs into smaller pieces to fit in stoves. Also has been used (not advised) to shorten fingers.
    Pole saw. A long pole with a chain saw at the end. It may also be used to strengthen your body and increase your vocabulary.
    Bull rope: Used when a tree needs some persuasion for accuracy in felling. Could also be used to lasso bulls but not recommended.
    Saw scabbard: A device to cover that sharp chain.
    Helmet: A head cover that works better than cloth hats to protect the head.
  13. RCBS
    There's always a method to the 'madness'. I've made a few Humbys mostly just to do them. I don't lay down near enough trees to ever tell anyone one or another way is more betterer. The flat toppers are most impressive to me, but they play with fire according to known safety standards.
  14. RCBS
    'Bar' Not a place to drink. Also not a blade. -Guide for chain to revolve around attached to saw. Not to be confused with Fubar, though they sometimes end up that way.
  15. imwiley1
    imwiley1
    Wisconsin
    Aspen-Populus tremuloides is a deciduous tree native to cooler areas of North America, one of several species referred to by the common name aspen. It is commonly called quaking aspen, trembling aspen, American aspen, mountain or golden aspen, trembling poplar, white poplar, and popple, as well as others.
    Popple- regional name also for Populus grandidentata, commonly called large tooth aspen, big-tooth aspen, American aspen, Canadian poplar, or white poplar, is a deciduous tree native to eastern North America.
    Both dry quickly, burn fast and hot, good shoulder season wood if other wood is available.
  16. Va Homesteader
    Va Homesteader
    Central Va
    Chunks and uglies = BTU'S that won't stack pretty
    Chill breaker = use those chunks and uglies to take the chill of the house early in the season.
  17. Horkn
    That's a bit different. I haven't yet tried the walt style splitter but I know I’d be all over that. Log lift and standing at a normal working height? Yeah. Sign me up
  18. Horkn
    Fuglies: see uglies above, ugly but burnable wood splits
    Blue Smoothies: always a plural thing. eatonpcat likes drinking these by the fire, known to aid in the human torpedo effect and the start of many funny and memorable stories.
  19. Eric VW
    :whistle:
    :sherlock:
    :bug:
    See “human torpedo”…. aka eatonpcat :rofl: :lol:
    Love ya, Bri….:wacky:
    :handshake:
  20. ironpony
    ironpony
    Mid Ohio
    Pallet, one ton of pellets
    Baggie, 40 pounds of pellets
    Pellets, the tiny logs that go into a pellet stove
    Ash Pan, the tiny tray you empty once a week
