192t problem
Discussion in 'Chainsaws and Power Equipment' started by Erik B, Oct 11, 2025.
  1. Erik B
    Erik B
    Western Wisconsin
    My 192t has been acting up. It starts fine and runs for a few minutes and then quits. If I let it sit for 20 minutes, it will run for a few minutes. If I let it sit for only 10 minutes, it won't run as long. I am thinking it may be a fuel problem not getting to carb. Could it be a partially plugged fuel filter? The longer it sits, more gas gets into the fuel line but when it starts, fuel isn't replaced fast enough to keep it running. Am I unto something or way off base?
  2. Chud
    Chud
    Does your saw go unused for long periods of time? Do you use E10 gas? Yes I think you’re on the right path of a fuel issue. If it’s not the filter, or fuel line, it’s the carb.
  3. Erik B
    Erik B
    Western Wisconsin
    I only use non-e gas. In all the years I have had the saw, this is the first time this problem has shown itself
    metalcuttr, brenndatomu and Chud like this.
  4. Jeffrey Svoboda
    Jeffrey Svoboda
    Does cracking the fuel cap affect the problem? Thinking maybe the fuel tank vent is plugged.
  5. Erik B
    Erik B
    Western Wisconsin
    I will try that.
  6. Erik B
    Erik B
    Western Wisconsin
    I talked to my friend who works at the Stihl dealer and explained the problem. He thought it sounded like an electrical problem. I changed the spark plug and all is right with the world.:thumbs:
  7. Va Homesteader
    Va Homesteader
    Central Va
    Ignition Coil
    eatonpcat, metalcuttr and brenndatomu like this.
