I will not fear tree service wood
Discussion in 'Chainsaws and Power Equipment' started by Casper, Sep 30, 2025.
  1. Casper
    Casper
    22 ton vert/horz box Store beam and cylinder. I have been breaking a few bolts and pins on this 33 year old beam with the excavator pump, but man it beats man handling big rounds! I'm only cracking them in four pieces and will put them through the push-through splitter on cool days.
    metalcuttr, eatonpcat, Chud and 9 others like this.
  2. Dok440
    Dok440
    NorCal
    That's my ultimate goal! Breaking pins on that setup is definitely first world problems. :rofl: :lol:
  3. brenndatomu
    I'm betting you can find something to stuff in there that's tough enough to find the next weakest link...:whistle:
    Nice setup :yes:
  4. Casper
    Casper
    I'm betting the piston seals and backup rings give up the ghost next.
  5. Krackle_959
    Krackle_959
    Coastal Maine
    Neighbor bought a Split-fire version last spring and put it on his Bobcat mini ex. Said it’s the best way to split firewood, sitting in a seat having an adult beverage with the ac on and tunes playing. He splits boiler wood for 3 wood boilers on his family farm, 6 trailer truckloads each winter.
    I’ve need to go check it out, and try it. Pretty sure I could get use to that for splitting big rounds into something manageable.
  6. Casper
    Casper
    I had this on my forks on my Kubota MX5100, running the splitter with hoses run from the rear remote ports. That was better than wrangling the big rounds, but this is SO MUCH better!
  7. T.Jeff Veal
    We have an old 25ton Yard Machine splitterI thought about converting to QA plate for front of tractor
  8. Casper
    Casper
    I've been doing that for the past few years and it works good. A real back and knee saver. I doubt you would regret doing it. I bolted the fork pockets on mine so I could return it to a vertical/ horizontal configuration if I wanted to. At this point I don't see that happening. It is way too valuable as is, or even as was (when fork mounted).
    ETA: I really like having the splitter off set to one side. It makes it way easier to make sure everything is lined up. I actually shifted my forks further to the left to make it even more visible.
  9. brenndatomu
    My brother has one on the SS...it's nice for the Biggins, but lining things up to split would be MUCH faster mounted on an excavator! Even a backhoe...hmm...put wireless remote control on the backhoe and you could be in the SS feeding, and splitting both! :thumbs:
