Carpenter Bees …
Discussion in 'Everything Else (off topic)' started by JimBear, Sep 24, 2025.
  1. JimBear
    JimBear
    I am waving the BS flag high & wide about these prigs not being destructive & only bothering untreated cut lumber …
    I was pruning a large cedar tree for my mother today & saw a couple carpenter bees floating around after dropping a couple of limbs.
    Any of you arborist type folks ever experience this ??
    Barcroftb
  2. bogieb
    Well, it is untreated wood :rofl: :lol:
    From the USDA
    From Wikipedia
    From a pest control site
  3. Barcroftb
    Barcroftb
    The Mitten
    I’ve never seen em go after a cedar. They must’ve been desperate. The various diy traps floating around the interwebz seem to be quite effective. You could always take a more active role in their destruction… these work well on them. IMG_6081.jpeg
  4. ironpony
    ironpony
    Mid Ohio
    When I lived at the other place we had lots of these bees. They bored into everything in sight, trees, decking treated and untreated, any species you could name. I had holes all over my cedar pergola in the handrails on the deck, wood siding, they will bore into anything they can chew. It looked like someone took a 1/2 drill bit and drilled holes on everything outside
    Where we are now I have not seen one.
  5. brenndatomu
    They don't like getting sprayed with brake cleaner either...:whistle: :D
  6. RCBS
    That's what they are supposed to be doing. Then I wouldn't have needed to put up metal flashing. 8 gazillion trees out there but my shed is your prefered choice of wood??? Same sentiment to Starlings that think they are too good to build a nest in a tree.
  7. T.Jeff Veal
    We have them bad down here. Some treated wood gets gnawed on sometimes...as Dave said brake cleaner shot into the holes will do them in.
    I was running some red cedar boards through the planer one day, bees started coming out with the shavings...
    metalcuttr, MikeInMa, JD Guy and 8 others like this.
  8. buZZsaw BRAD
    Pesky bastages. They bore into almost anything wood around here, including PT. Back in May i did a job on a garage that had bunches of them chewing on the rake trim. Their buzzing and hovering annoys the chit out of me when working. I killed quite a few with my hat and swatting them with a piece of trim while they're airborn. They chew the fascia on our all wood siding leaving a line of sawdust on the front door mat.
    First I've seen them on wood in nature.
    metalcuttr, MikeInMa, JimBear and 3 others like this.
