Ryobi splitter not wanting to split
Discussion in 'Chainsaws and Power Equipment' started by cezar, Sep 22, 2025.
  1. cezar
    cezar
    KY
    This is the generic 6 ton that comes under a million brands from the big box stores.
    It's never been particularly strong but it's gotten worse after sitting idle since last fall. The first 1/3 of the stroke is......adequate but it starts to fall off and by the second half of the stroke it's barely moving at all.
    Is there anything that can be done? Right now it won't split about half the wood I have..
  2. brenndatomu
    Sounds low on oil...have a manual for it?
    Usually, you stand it on end and there is a plug to take out for oil fill...as far as how to check the level...depends on the exact model?
    jmb6420, eatonpcat and theburtman like this.
  3. brenndatomu
    I couldn't find a Ryobi, but they're all pretty similar...here is a manual, oil change on page 10
    7TYHS520-A manual.pdf
    buZZsaw BRAD, RCBS and eatonpcat like this.
  4. cezar
    cezar
    KY
    Gonna go pick up some hydraulic fluid and try that. Will report back.
    buZZsaw BRAD and eatonpcat like this.
  5. cezar
    cezar
    KY
    Also where do you go to buy ISO 22 hydraulic oil? Autozone doesn't carry it and NAPA only has 5 gallon buckets.
    I assume RK and TSC have it but neither are near me.
  6. brenndatomu
    Napa doesn't have snow plow oil? That is often ISO22.
    Do you use it in real cold weather a lot? If not then I'd have no issue putting a more standard weight hydraulic oil in it...like AW32, or if you want to go ahead and change the oil, you could put ATF back in it.
  7. cezar
    cezar
    KY
    I don't use it below 40F.I actually only us it between 40F and 60F for comfort reasons.
    I definitely want to fully change out the oil. ATF would work you say?
  8. cezar
    cezar
    KY
    From doing some reading it sounds like AW22 and ATF are better for low temps and AW32 is better for high temps. It sounds like 32 is similar enough to 22 to work--and I can get 32 at Autozone..
  9. Eggshooterist
    Eggshooterist
    Erff
    I put kubota Super UDT 2 in mine because I had some left after my tractor service. Works like it should.
  10. RCBS
    The bragging that goes on around here! (I know how much that stuff costs)
  11. Eggshooterist
    Eggshooterist
    Erff
    Good thing it takes me 12-13 years to hit the 400 hr service interval. :makeitrain"
    RCBS, theburtman, brenndatomu and 2 others like this.
  12. cezar
    cezar
    KY
    So if I put AW32 in instead of AW22 in, is that going to affect the splitting performance at all? BC I'm willing to special order and wait for the 22 if the 32 is going to diminish my splitting capacity.
    This splitter is such a freaking bottleneck it's unreal. I can't afford a proper splitter but I'm absolutely drowning in rounds that I have NO ability to split. Like, I have probably half a cord of osage from the springtime that isn't even in the ballpark of being able to split. It's fun to hit it with my Fiskars axe. Watching it bounce off as if it's concrete is entertaining. Every month that goes by, the wood hardens up further. I can't justify renting a splitter either just for the fact that I have wood to burn, just not the stuff I WANT to burn. I can't even noodle the osage. Not even with a 90cc saw and a fresh chain. IT THROWS SPARKS.
    brenndatomu and buZZsaw BRAD like this.
  13. brenndatomu
    At 40-60*, AW32 will do just fine, may even improve performance a bit.
  14. brenndatomu
    What does your wedge look like, pretty sharp, kinda like an axe, or more of a triangle shape? I've noticed the wedges on those little electric splitters are not all created equal.
    On mine it has a pretty sharp/narrow wedge that has a radius/taper to wider at the back, and it is rarely stopped.
    My sister has a similar machine, but the wedge on it is more like a simple triangle shape, kinda blunt, certainly not terribly sharp, and it can be stalled out easily.
    I was going to take a 6" grinder to the wedge to modify it, but my brother ended up finding a different machine for her (a huge upgrade too!)
  15. RCBS
    I got about another year before I have to buy 12 gallons of it.
  16. Eggshooterist
    Eggshooterist
    Erff
    Mine holds almost 7 gallons. I don't remember what I paid per jug.
    RCBS, metalcuttr, cezar and 2 others like this.
  17. cezar
    cezar
    KY
    Cool! I'll just do that.
    So anyway, checked the fluid level and it was barely on the bottom of the dipstick. Dunno where it all went but it was basically empty. Chucked some ATF in there figuring (a) it wouldn't hurt and (b) might help flush it out for when I put fresh fluid in.
    Instant night-and-day improvement. I'd forgotten how well the thing could work.
    I'll stop by and get some AW32 and do a proper change later today.
  18. cezar
    cezar
    KY
    While we're on the subject of splitters, I think I want to upgrade in a few years. Something with a faster stroke and ideally something that can do 4x splits at once.
    What is the 240v splitter world like? I have no interest or use for an engine but I have a breaker box directly on the other side of the wall from where I split, so I could easily run even a 60amp circuit if I wanted to for like no money.
  19. brenndatomu
    Good idea...that atf will help clean things up in there.
    I built one out of a standard ole Huskee 20 ton...I used a "5 HP, 3600 RPM air compressor special" motor, but it's more like 4 HP real world (16A/240v) I had to turn my pump shift pressure and my relief pressure down a bit, but it still splits almost anything.
    I did find a great deal on a true 5 HP motor (20A/240v) since then...haven't swapped it over yet, as like I said, it works pretty well as is.
    That replacement splitter I mentioned earlier that my brother found for our sister is 120v, but it is one of those 2 way splitters with a knife...splits both directions...I'll hafta find the brand/model.
    metalcuttr and eatonpcat like this.
  20. cezar
    cezar
    KY
    Intredasting. So in other words, I might be able to find a splitter with a blown engine and toss a air compressor motor on...
    metalcuttr, eatonpcat and brenndatomu like this.
