Anyone Make Their Own Charcoal?
Discussion in 'The Smokehouse' started by buZZsaw BRAD, Sep 18, 2025.
  1. buZZsaw BRAD
    Friend of mine gave me this bag of lump charcoal. I've seen and used it before and know it burns faster. I have used embers of hardwood pulled from the firepit before in the grill with good results.
    Looked online on how to make it your self and it seems easy enough. May give it a try as I'm manning the firepit and smoker during an extended cook. Seems easy enough, just time consuming. DSCF0120.JPG
  2. RCBS
    So what are the chances that I just watched this last night trying to learn myself something?
    I'm not looking to turn up a batch, just seems like something good to know.
  3. buzz-saw
    buzz-saw
    Ct.
    I tried , either use coals from the firepit , wood................
    or buy it. It was a pain in the a-- .
  4. MikeInMa
    It seems that a lot of wood is consumed in the making of charcoal. Lump charcoal generally burns hotter than briquettes.
    I just buy briquettes by the bag. But, I don't have an offset smoker so I can't comment on how they behave.
    If I want to grill over coals, I'll split a few splits thinner and have a quick fire.
  5. Eric Wanderweg
    It IS a laborious process. A while back I got interested in making black powder, which sent me down the charcoal making rabbit hole. Back a couple generations ago (especially here in the northeast) they had huge brick kilns packed with dozens of cords of wood to do the job. Making it on a smaller scale doesn't seem too difficult if you've got all the time in the world and proper equipment though.
  6. buZZsaw BRAD
    I watched a video and all the guy did was fill a galvanized steel five gallon pail with splits, cut a vent hole in the lid, and put it in a fire. Took several hours. I've got plenty of BL chunks here.
  7. spotted owl
    spotted owl
    PNW
    Bark, use as much bark as possible. The Kingsford plant has a mountain of bark that they feed into the plant. We goofed around a couple times and bark did much better but runs out fast than wood lump.
    Yea, what Buzz-saw said. It’s a dirty pain in the axe.
    Owl
  8. metalcuttr
    metalcuttr
    western WA
    Not sure I would use anything galvanized though. I don't like the thought of any heavy metals introduced into my food processing! Would be fine for charcoal for gunpowder though.
  9. buZZsaw BRAD
    Valid point. Looks like the guy in this video used one.
    eatonpcat and metalcuttr like this.
  10. metalcuttr
    metalcuttr
    western WA
    Having done a lot of welding/ cutting in the past and having had a mild case of galvanizing poison, I don't want to have anything to do with zinc and high heat. Maybe that is not a problem with this process or maybe the amount of oxide generated is not a problem if ingested instead of aspirated. BUT, I highly suspect that the inside of that can is covered with white zinc oxide and that the poster of the video, well meaning as he may be, has never had zinc poisoning. In any case, better safe than sorry for me! The process is very interesting and if I ever tried it for cooking charcoal I probably would use a 16 gallon mild steel barrel with the paint burned off and scrubbed and washed out.
  11. buZZsaw BRAD
    I never knew about issues with zinc. Actually learned about potential problems fabricating it on here. Having used a lot of lead for chimney flashing and roofing I was very mind full to wear gloves when I worked with it.
    Ill have to check if Tractor supply or a similar store sells plains steel pails. Why take the chance with the galvanized. The galvanized pails I have are for charcoal briquettes and birdseed storage. I did post a question on that you tube video about using a galvanized can.
    T.Jeff Veal, eatonpcat and MikeInMa like this.
  12. ReelFaster
    ReelFaster
    S.Jersey
    I thought about it but looked like more trouble than it was worth. The little I use to get the smoker going with a nice coal bed is done with a cheap $10 non lump bag.
  13. buzz-saw
    buzz-saw
    Ct.
    This exactly , I use cheap briquets to get mine going also. Start them in a charcoal chimney , dump them in the firebox of the smoker then start slowly adding wood. I do this instead of starting a fire directly in the firebox to avoid the dirty smoke from startup
    Cheap , easy and works perfect.
  14. lukem
    I used to make a lot, but now that I have an OWB it is basically a charcoal factory.
    Get a 55 gal drum and a 25-30 gallon drum with a lid. Food safe, all that stuff.
    Cut the top and the bottom off the 55 and set it on 3 bricks (keep it off the ground for airflow).
    Fill the small drum with 3"-5" sticks of wood and put the lid on.
    Place the small drum inside the big drum.
    Fill the space between the drums with any kind of scrap wood, twigs, cardboard, whatever.
    Light the wood between the drums. Keep feeding it.
    When you get clear gas or the smoke coming out of the small drum it no longer flaring off (burning) it's done cooking. Stop feeding the fire and let everything sit untouched for 24 hours.
  15. T.Jeff Veal
    Yep, that zinc poisoning is nasty. I had it when I was young teen and dad was teaching me to weld. Built some side bodies for his truck out of galvanized pipe...took awhile to get over that
  16. Jeffrey Svoboda
    Jeffrey Svoboda
    Take that one step further and do something with the wood gas coming out of the small barrel. My cousin has said there are guys on YouTube powering vehicles with it.
  17. woody5506
    woody5506
    Upstate NY
    I've made mine with good success but it does require a good amount of fuel (wood) to produce a far lesser amount of charcoal....if that makes sense. but for us wood hoarders that usually isn't much of an issue as I'm sure in general most of us have plenty of junk wood to burn anyway. I'll try and dig up pics later of my process, but the outcome was good. Just not as good as a premium brand like Jealous Devil or B&B. Those lump brands are noticeably heavier/denser and burn far longer than what I made. I suspect thats just because my process was not perfect. Those brands are using proper kilns and really snuff out the fire as where I was using an old metal bucket, holes cut on top of the lid, then snuffing it out with dirt over the holes once it reached proper temps. There was still smoke escaping from around the lid during that process so really it's just not going to be "perfect".
    There's a guy not far from me who sells firewood and now lump coal. I tried a bag, which was pretty expensive at $30 for a 20lb bag. His was very similar to mine - it lights very fast, but that means it burns fast. it wasn't nearly as dense as it should be. Basically, I suspect his process was similarly imperfect like mine. I determined these homemade lump coals are good for quick charcoal grilling at home, but would be a major headache and waste for running a smoker for 8+ hrs. it would require probably more than twice as many reloads as it does from a proper lump coal like Jealous Devil.
  18. buZZsaw BRAD
    Im wondering if denser wood species make a difference? I have plenty of black locust chunks and nuggets that were cut dead and/or long down so plenty dense.
    I just have to find a decent non galvanized pail to use. I have a couple nice galvanized ones with locking lids that would be ideal.
  19. woody5506
    woody5506
    Upstate NY
    I made mine out of red oak and hickory. I'm sure a softer species of wood would be far less ideal but even the hickory still came out not totally ideal. usable, just not premium quality!
  20. woody5506
    woody5506
    Upstate NY
    Here's a few pics of how I did it....
