Woodstock Soapstone Progress vs Absolute
Discussion in 'Modern EPA Stoves and Fireplaces' started by SeachangeWoodBurner, May 4, 2025.
  1. SeachangeWoodBurner
    SeachangeWoodBurner
    Brunswick, Maine
    Well, I joined Firewood Hoarders! Yay! We are in the midst of doing our due diligence on replacing our 20 year old+ VC Encore with a new stove. REALY like Woodstock Soapstone Sotve Company. Visited facotry- impressed with overall business model, care, details, quality.
    We have a 2800 sq.ft. home, however no ideally set up for total wood heat. Impressed by both the Progress and the Absolute. Specs on both put our needs well in the comfort zone. Looking for comments from folks who have used either (or both) of these stoves. Cons - Pros - comments?!
    Thasnk you
  2. Highbeam
    Highbeam
    Both smaller stoves. Have you seen the IS model?
  3. Canadian border VT
    Progressive is big soap stone. total soapstone cast iron frame Not a steel stove 2.8 cu ft firebox
    Ideal steel, I have and use is bigger than absolute steel.. steel stove soap stone inserts 3.2 cu ft firebox
    you will want a big stove
    Welcome to the FHC :handshake:
    Oldhippie I know has an AS
    Backwoods Savage is Woodstock knowledge base
  4. brenndatomu
    Welcome!
    Describe your setup, floorplan, home size, and insulation/heat requirement levels please.
    Do you have wood dry/ready to burn...I assume you do since you have the VC already?
  5. cezar
    cezar
    KY
    If I was gonna buy a new stove it would be either Blaze King or Woodstock. Slight edge to BK due to their community engagement and customer support.
  6. Highbeam
    Highbeam
    These brands have the best tech but some pretty weird looking stoves! The kuma guys make some high performers too but nothing really big.
    LE Wood Stoves, Freestanding LE Wood Stoves by Kuma Stoves
    brenndatomu likes this.
  7. VTAbstoluteSteel
    VTAbstoluteSteel
    Orange County, VT
    For that SF I would go with a Progress or Ideal. I think the AS would be too small.
    I also like side loaders (Progress) vs. Front Loaders (Ideal). I like keeping everything off to the side, opposed to moving it to the front of the stove to reload.
  8. Canadian border VT
    Yes side loaders are great BUT remember how much wall space you need. IMO 6 feet to side of stove and no corner insulation
  9. Highbeam
    Highbeam
    I had a side loading hearthstone and really liked it compared to a typical front loader that is shallow so you have to chuck wood in sideways. A well designed front loader that is deep so you can load wood straight in as you would with a sideloader makes all the difference. The IS is designed this way, as is the BK line. Chucking wood in sideways is the enemy.
    Whoa, those are huge pictures. DOn't know how to fix it. Sorry.
  10. Oldhippie
    Oldhippie
    Ashby Ma
    2800 sq. ft. is a lot of space. But if it wasn't originally set up for woodstove heating, perhaps the biggest stove isn't needed. You need to prioritize your requirements. If you are looking to heat the entire house with a single stove, big is good. Then the Progress, Ideal or the BK. Problem with the BK is the cost of getting it to Maine may put it out of the running just due to shipping cost.
    If the stove's beauty is important, the Progress is a winner, and it will heat as much as you need. If pretty isn't high on the list, the Ideal is also excellent. The Absolute Steel isn't that much smaller, and it's a great stove.
    Given you live in Maine, between the quality of the stoves, AND EXCELLENT customer service, you can't go wrong with Woodstock Soapstone.
  11. brenndatomu
  12. Flamestead
    Flamestead
    Windsor County, VT
    I’ve run the PH, IS, and AS at different times on the same flue. They were developed in that sequence, so the AS has their most experience in its design. The AS is the smallest of the three. The PH puts out the most peak heat, while the IS can flatten that peak out better.
    We are in a bigger house than yours and push the stove to burn 7+ cord per year (about 80 cord through the PH by now). I’ve been deep into the PH several times to replace parts, but I don’t read here of others having to, which suggests it is related to how much heat we try to get it to put out.
    The company is 1st class service.
  13. DNH
    DNH
    Missouri
    Had a Progress Hybrid, sold the house, but still keep up with the owners and Woodstock.
    Woodstock has redesigned the Progress Hybrid air flow to be more similar to the IS. This should allow the PH to still put out the max heat on demand but also allow a longer and lower burn similar to the IS.
  14. Todd
    Todd
    NW WIS
    I asked Woodstock about the PH modification and if they had any new burn times or lower end BTU numbers with this new mod and they said they were still waiting on the test results and will post them once received. They can’t ship a PH til they get this.
    Also told me with the new testing method they had to tweak the air to deliver more air in the closed position. More air probably means less burn time and higher BTU low end output but we’ll see? Too bad they didn’t stick with the cordwood testing which was more real world than the stupid crib method. You can thank 10 states that sued the EPA to change it back in 2023!
  15. Highbeam
    Highbeam
    Sure would be nice if the tweak for more minimum air was easily adjusted. For testing of course.
    Todd and brenndatomu like this.
  16. Todd
    Todd
    NW WIS
    Ha yeah. I also noticed the Fireview was retested and they mentioned in the test report that they changed the minimum air on it as well. The lower end BTU is a little higher at about 10,000 when it was about 8000 with the old cordwood test.
