  1. Dpopps
    Dpopps
    MI
    Did you need a new tank or just wanted it outside?
  2. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Hope this finds Y'all doing well.
    The past month has been a train wreck.
    My tenant that rents our apartment downstairs decided to move on....Arrrrrrgh
    NO LOVE LOST WITH THIS ONE.
    She paid well....Serious attitude issues.
    She left the place intact with no damage..But left us with a serious mess to clean up....
    Been trying to get the North side deck finished.....We have one section done....PHASE TWO will have to wait until next year now..
    We were lucky and were able to get a young couple signed on within a week.
    Still the upset wasted a bunch of time that could have been spent on the deck.
    Yesterday was nasty....82 F with 70% humidity.
    We rarely see this type of Humidity with heat......We get months of 90% + humidity.....but temps are in the 40's- low 50's with rain .... Hot weather here usually sees humidity of 20%- 30% or less and low teens is not out of the question.....
    Yesterday even the AC floor vents started to sweat...:eek::eek:
    Been in this house for over 30 years...Never seen that trick....MUGGGGGGGY
    But this morning the humidity has moved on ....
  3. jtakeman
    We had an inground tank. Home owners insurance has been tougher to get because of it. So phase one was to get this tank installed and phase 2(hoping later this fall) is to get the old inground removed.
    Should be easier and cheaper on the insurance? We shall see, I bet they find some other stuff to be a PITA!!
  4. Dpopps
    Dpopps
    MI
    I didn't even know they did inground tanks, I don't think oil burners are very popular in my state.
    Outside tank sounds safer and easier to check levels on. Hopefully you get a insurance break.
  5. jtakeman
    The tank was installed way back in the 60's. Originally had a tank(1939) in the basement, But when they built the addition they removed it and they did the inground. No longer able to do so by DEeP standards these days.
  6. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Summer is winding down now...
    A few showers the other day and this Sunday looks wet.
    Starting to think about stove season and getting ready to get shells.
    The skid steer has been sitting all summer with a flat tire.
    I fired it up yesterday and got it up to the house where I can get the flat off and to the tire shop today.
    We have had 29 years of boarding horses here at the ranch and that is coming to an end.
    Our old guard (3 horses) have all crossed the bridge now and the last two that are boarded will be leaving at the end of the month for a barn that is much closer to where the owner lives now.
    Gonna feel like a house with all the children gone.
    So the skid steers duties will be strictly for loading the dumpster on the trailer this winter.......
    My last tenant in the apartment here at the ranch moved on and left me a 2002 Chevy venture (Dead)
    She left the title and the keys ...So yesterday we had thew local Pick N Pull come drag it off.
    They do pay some $$$$$ for the dead ones.......
    New tenants moving in the first of Oct.....
    Times they are changing.....
    gbreda, bogieb, IHATEPROPANE and 3 others like this.
  7. Dpopps
    Dpopps
    MI
    I'm planning on getting a xxv, so I decided to download the manual. It says you can use a 3 or 4 inch vent pipe. My last stove had a 3, any benefit using a 4?
  8. jtakeman
    If installed above 4000' or the run is long and more than 2 90º bends or tee's the 4" is a must. Best to determine the IPL or EVL(metric) if you installing more than a simple up and out run.
    IHATEPROPANE, gbreda, imacman and 2 others like this.
  9. bogieb
    What jtakeman said
    Does your thimble from your previous pellet stove have an OAK pass-thru already? If not, it might be a great time to go ahead and replace it (assuming you are putting in the same place).
  10. Dpopps
    Dpopps
    MI
    It should be a simple run, wasn't sure if there was a benefit using a 4 inch? EVL is under 600
    IHATEPROPANE, gbreda and jtakeman like this.
  11. Dpopps
    Dpopps
    MI
    I would like to get a thimble that has a built in oak. Not sure what big box has the better brand or options?
  12. Dpopps
    Dpopps
    MI
    I seen 2 different used xxv for sale and there both less than 3 hours away. Unfortunately I don't have anywhere to store it currently.
    IHATEPROPANE, imacman and jtakeman like this.
  13. jtakeman
    I haven't seen much benefit on short runs. I actually saw a disadvantage with a short run of 4" were the draft could not be reduced enough. Had to change the cap with a more restrictive cap to balance the draft readings.
    I personally haven't done any long runs, But did do a short run that required 2 tees and a 45º and the 3" was a bit too restrictive. Magnehelic readings were a bit too low(I could not to get the mid range of the recommended reading on an enviro EF3), But the stove seemed to run OK. We will swap it to 4" if there is ever an issue. The draw back is they have to run it with the damper almost wide open, But the flame is good.
    IHATEPROPANE, imacman, gbreda and 3 others like this.
  14. bogieb
    Most sell Selkirk/Duravent or Pellet Vent Pro. Pretty much the same thimble (the pipe itself has some differences). so just go with whatever business has it on sale / for the best price when you are ready to buy.
  15. Dpopps
    Dpopps
    MI
    I want the thimble installed during the build. It should look nicer and be more air tight that way. I'll have to try and figure out how I'm going to run the pipe.
    The only option for the exhaust will be facing a very windy area, not sure how to best navigate that?
    IHATEPROPANE, imacman, bogieb and 2 others like this.
  16. jtakeman
    I haven't seen exhaust issues in windy area's. But have seen issues with oak's with high wind.
  17. Dpopps
    Dpopps
    MI
    The exhaust pipe and oak will be facing winds hitting 30-40mph regularly and 80+ other days. I will be putting up a snow fence and at some point the snow drifts should cut the wind down some.
    My last stove had the clean out T directly attached to the stove. If I did that with this install, I would probably have 2 90's 18-20" vertical and 6' horizontal.
    IHATEPROPANE likes this.
  18. bogieb
    For the exhaust you can either get:
    • A "jet" termination as the installer used on my P61a (1st pic). Note that the installers used a brand of exhaust pipe made in the Midwest, so may or may not be available for the brand you chose.
    • or use a 45* elbow for a termination to deflect the wind - which is what I chose when I installed the smaller stove (2nd pic from the P43). Although it looks like the termination points down, it actually is at about a 45* angle
    Make sure the thimble you get has a built in deflector shield on it, as can seen in the second picture
  19. Dpopps
    Dpopps
    MI
    Did you go with a 4 inch exhaust for the smaller stove in the second picture? Do you know what brand or where the thimble with the oak deflector is from?
  20. Dpopps
    Dpopps
    MI
    Sounds like I should get a 4 inch. The run will be short but with one T and 2 90's and possibly another 90 on the outside before the termination cap.
    Sounds like I'll need to get a gage thingy doohickey, to dail the stove in?
