Has anyone repaired a cracked firebrick with refractory cement?
Discussion in 'Modern EPA Stoves and Fireplaces' started by don2222, Sep 10, 2025.
  1. don2222
    don2222
    Salem NH
    Hello
    I see it can be done but has anyone done this?
    Is any refractory cement or refractory mortar adaquate?
    See info below
  2. spotted owl
    spotted owl
    PNW
    Why not just change out the brick?
    Owl
  3. don2222
    don2222
    Salem NH
    I have a brand new one, I wanted to try and fix.
  4. brenndatomu
    Yup, furnace cement works great! I've also repaired cracked baffle boards with it too
  5. Screwloose
    Yup it works quite fine. I know it survives industrial kiln furniture.
  6. Backwoods Savage
    It works. Firebricks are not expensive too.
  7. theburtman
    theburtman
    I would just get a new brick.
  8. MAF143
    MAF143
    North Central OH
    $25 for a box of 6 firebrick and a 50 mile drive to get them isn't exactly always in my $ budget or time budget.
    I normally have spares on hand, but I'm not gonna get out the diamond blade on the angle grinder to cut a special sized brick at night or in the middle of a snowstorm. I'm for sure not gonna cut them inside the house... If its a full size one I'll replace it sometimes. But if it's a simple halfway clean break I'll glue them back together. The brick at the front of my stove take a beating. I run hot cuz we have a lot of house to heat.
    My woodstove pretty much runs 24/7 from October till April.
    I've used this stuff to glue firebrick back together many times over the years.
    metalcuttr, MikeInMa, cezar and 2 others like this.
  9. brenndatomu
  10. lukem
    I don't have a stove anymore, but I didn't worry about cracks unless there was a big gap or the brick was in danger of falling/moving out of place.
    RCBS, metalcuttr, Warner and 4 others like this.
  11. wildwest
    Stove at old home in Colo had cracked bricks, we didn't bother since they stayed in place fine and no gaps.
  12. GranpaJohn
    GranpaJohn
    Central Maryland
    Hope this works...
    Baffle board repair
    Eta...after the first year I think I replaced the baffle board. Just didn't hold up with new cracks. The brick, however, seems to be pretty strong. Hope this helps.
  13. Highbeam
    Highbeam
    If it's just cracked but fully in place then run it. If it falls out because of the crack then try to swap it with a floor brick where it can't fall down.
  14. don2222
    don2222
    Salem NH
    What do you mean by a floor brick?
    metalcuttr likes this.
  15. Highbeam
    Highbeam
    On all the stoves I’ve owned, other than a hearthstone, the wall bricks are interchangeable with floor bricks. As in the bricks on the firebox floor.
    brenndatomu, don2222 and theburtman like this.
