Looking for DRY sand to mix with oil based sealcoat.
Discussion in 'The DIY Room' started by Screwloose, Sep 7, 2025.
  1. Screwloose
    I need to seal my driveway and I'm using oil based sealer. Trying to find a hundred pounds of sand to mix in.
    Fine silica dry sand.
    Wondering how clean used aluminum oxide blasting media would work.
    Any thoughts?
    John D, wildwest, JimBear and 2 others like this.
  2. brenndatomu
    I'd think it'd be fine...I've used bags of regular ole playground sand before, seemed to work good
    John D, wildwest, eatonpcat and 2 others like this.
  3. Screwloose
    Maybe I'm overthinking it. The stuff I'm using is mineral spirits based.
  4. brenndatomu
    Hmm...I dunno, try a "test patch" in the back lot somewhere?
    John D, wildwest, eatonpcat and 3 others like this.
  5. buzz-saw
    buzz-saw
    Ct.
    That was my first thought as soon as I read the posting. You know it is "DRY". Why wouldn't it work. Probably a little overkill but it is just a high grade sand.
    John D, wildwest, Screwloose and 2 others like this.
  6. buzz-saw
    buzz-saw
    Ct.
    If you were just a little closer.
  7. Screwloose
    Someone also suggested pool filter sand.
  8. buzz-saw
    buzz-saw
    Ct.
    Sure , that would probably be a cheaper alternative. I would question how dry it is . Being a filter sand that is run in a tank full of water they might not be as dry as blasting media that is processed so it is dry and stored to stay dry as well. Moisture in blasting media doesn't work well. What we call Black beauty here is a blasting media that is rather course and it is black in color as well.And inexpensive.
  9. Screwloose
    Black beauty is what I use for the pressure blaster outside. Could be a little course though. I was thinking about the aluminum oxide as our cabinet blaster could use a dumping, could be too fine.
  10. ironpony
    ironpony
    Mid Ohio
    Personally I would go with play sand dry, cheap, readily available 2nd pool filter sand. I think it will all be very dry as no one wants to pay to ship water weight. Quikrete might have sand available too
    If you have free blasting sand that would be even better, free
  11. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I work at a gravel pit so I’m a bit familiar with sand. Seems like a bunch of over thinking going on here. A completely full 5 gallon bucket of sand will be in the neighborhood of 90 lbs.
    so go buy a couple bags of whatever sand you choose ( play ground, pool filter, ice traction,) I’m sure it’ll be dry enough for what you want to do. If not pour it out on a tarp on your shop/garage floor for a day or two and stir it occasionally.
    If you go to your local redi mix plant or sand and gravel operation. They will probably give you 5 or 10 gallons of sand if you’re willing to scoop it yourself. or you could bring your dump truck to my work and I’ll load you all you want of the stuff for five bucks a ton
  12. Ohio dave
    Ohio dave
    Akron, OH
    That's what we use on the ship for non skid. Works great as non skid but tears up hoses when we drag them across it
  13. imwiley1
    imwiley1
    Wisconsin
    Mason sand and pool filter sand are screened to a consistent size. Play sand can be hit or miss depending where you buy it.
  14. Butcher
    Butcher
    How much sand you want?
    billb3, sms4life, Locust Post and 8 others like this.
