Chain tension
Discussion in 'Chainsaws and Power Equipment' started by Ohio dave, Sep 5, 2025.
  1. Ohio dave
    Ohio dave
    Akron, OH
    I have trouble getting my 500i tension tight. The screw moves the pin without the bar, .but when I put the bar on it will only go so far. Not tight enough. I don't see any bad spots on the screw. Its almost as if the pin isn't long enough. Trying to run a 25 in bar the same size that came with it
  2. The Wood Wolverine
    Is your chain the proper number of drive links? Or did it possibly stretch so far it’s beyond saws range to tension it?
  3. Ohio dave
    Ohio dave
    Akron, OH
    New chain and I bought it from a stihl dealer after I told him the model and bar. Also there's still room on the screw drive
  4. Eric Wanderweg
    I almost wonder if the dealer miscounted the drive links when making the chain from the roll. Nobody’s infallible.
  5. Ohio dave
    Ohio dave
    Akron, OH
    I think they were precut and packaged
  6. The Wood Wolverine
    With the clutch cover on and no bar, can you run the tensioning pin from one end the whole way to the other?
  7. Ohio dave
    Ohio dave
    Akron, OH
    I haven't tried without the bar and the cover on. I'll give that a try Monday. I'm at camp till then
  8. Haftacut
    Haftacut
    Rives Junction, MI
    At c
    amp without your chainsaw?:saw: I’m so confused:rofl: :lol:
  9. Ohio dave
    Ohio dave
    Akron, OH
    Without the big boy. I keep the ms250 in the truck
  10. Ohio dave
    Ohio dave
    Akron, OH
    Since I had to go home for something else I grabbed the saw. Yep the pin will go all the way out and all the in without the bar but with the clutch cover on
  11. Ohio dave
    Ohio dave
    Akron, OH
    So I took the pin out and didn't notice any damage to the worm gear pin threads or the gear attached to the adjustment screw. It seems that the gear and the worm drive are slipping on each other. Like one of them is moving away from the other when tension is applied.
  12. The Wood Wolverine
    Can you replace that worm gear/screw assembly? Sounds like it’s the problem.
  13. Ohio dave
    Ohio dave
    Akron, OH
    Exactly what it was
    Haftacut, RCBS and The Wood Wolverine like this.
