Stove Brite "brush on".....Sprayable?
Discussion in 'Modern EPA Stoves and Fireplaces' started by woody5506, Aug 14, 2025.
  1. woody5506
    woody5506
    Upstate NY
    I've got a customer wanting me to help him restore an old VC stove that's currently enameled. I will blast all the enamel off, and repaint for him but my question is has anyone gotten stove brite "brushable" in the pint or quart containers, and thinned it out to run through a normal paint gun? In my case I would just use a gravity gun, or I could run it through my pressure pot depending on how much there really ends up being to paint.
    Stove Brite is advising my customer their "brush on" paint is NOT thinnable, and I find that hard to believe as any solvent borne paint can be thinned whether it's "recommended" or not. I suspect more so that they have made a product that's already on the edge of being VOC compliant, and they have to tell people in order to cover themselves as a company that it cannot be thinned and sprayed, which would only add to the VOC percentages. This is especially a concern for paints like this that are available to the general public rather than "professional use only" because most people aren't spraying in any type of controlled environment/paint booth.
    I've sprayed all sorts of industrial high heats at our shop but in general we do not use residential grade coatings. So my question is...has anyone sprayed that stuff out of a paint gun?
    wildwest, metalcuttr and MikeInMa like this.
  2. brenndatomu
    Why not just use the spray can? It works just fine, especially for high temp paint, which is not hard to get to lay down nicely...
    wildwest and metalcuttr like this.
  3. woody5506
    woody5506
    Upstate NY
    Anything in a spray can is like water, and especially over blasted cast iron it's just going to take forever to make it look right because that substrate soaks it all up like a sponge. It will cost more in material for that reason, more in labor on my end etc etc. You can get a far better finish, film build and efficient job shooting from a spray gun vs aerosol can. We run a busy industrial shop, so jobs like this are in no way our bread and butter but I do enjoy doing them, but if it came down to using spray cans on this it's just simply not worth my time. This would be similar to recommending a body shop do paint correction on your car with spray paint. They just wouldn't.
    wildwest, metalcuttr and brenndatomu like this.
  4. Woodtroll
    Woodtroll
    Mtns of SW VA
    Why not prep the stove and a piece of scrap at the same time, thin the Stove Brite and shoot the scrap, then if results are good move on to the stove?
  5. woody5506
    woody5506
    Upstate NY
    I could, but the real test would be how it does over time once it's actually brought to it's running temp and that would mean once the stove is all re-assembled, paid for, reinstalled etc. Last thing I'd want is a customer paying me good money and then the thing bubbles up or cracks during its heat up because the paint wasn't actually cured properly. I got a hard time believing that Stove Brite is overly unique in that it "can't be thinned" as they say but it's one of those situations where I would rather not find out the hard way. It's not like the big manufacturers who coat their stoves at the factory with stove brite are using spray cans or brushing it on....They are absolutely spraying them.
    Stove Brite reps can't even tell the customer if their paint can just be used right over his old enamel!! They made him go through some chain of command there and now he's waiting for an official answer from them. I would think that should be a pretty simple "NO" answer...
    I tried to just push the guy to use Rustoleum BBQ paint - the tech data sheet even mentions it being good for stoves too, it's thinnable, sprayable, etc. I've used this on other stuff for customers who requested it, like fireplace surround panels and such. Sometimes this is why the "side jobs" turn into way more of a headache than they are worth.
  6. RCBS
  7. woody5506
    woody5506
    Upstate NY
  8. brenndatomu
    I like that stuff...they have a flat and a satin option, Ive done some stoves with the body flat and the door satin, turned out looking really nice!
    metalcuttr and wildwest like this.
  9. woody5506
    woody5506
    Upstate NY
    Rustoleum has figured out how to make practically all of their products just about fool proof and there's certainly something to be said for that! I tried to push it but the customer didn't seem too interested. I think he's stuck on a certain stove brite color that of course is only available in spray cans.
    metalcuttr, wildwest and brenndatomu like this.
  10. cezar
    cezar
    KY
    POR-15 is wild. I used the top coat to refinish a box-blade/grader. JUST the top coat, mind you, after prep with a flap disc.
    It's held up like you wouldn't believe. Years of scraping my driveway and none of it's worn off.
  11. Highbeam
    Highbeam
    Cans of stovebrite are not the same as 76 cent cans of krylon. As someone who has bought very expensive cans of spray paint for auto body work I can assure you that there are different qualities of spray paint and good cans can be just as good as a paint gun. You just can’t mix hardeners and thinners.
    Just use the stove brite cans. You’ll be surprised at the coverage.
    I have used rustoleum high heat 1200 on my shop stove and it did not hold up to the heat. Chalking and white areas at temperatures below 800. So I only recommend the rustoleum if you are selling the stove and want to screw the buyer.
  12. Locust Post
    Stove brite has acetone in the formulation so I can't see why you couldn't thin and spray it.
    woody5506 and brenndatomu like this.
  13. woody5506
    woody5506
    Upstate NY
    Yeah there's varying qualities of rattle can paints, but the fact that they need to thin it down to such an extent to even be able to spray out of an aerosol can at hardly any pressure tells you that, for example, 2 solid coats out of a paint gun would be many coats out of a spray can. you spray something about as thin as water out of an aerosol can over blasted cast iron, watch it suck in and repeat the process many times and you may get a similar outcome to a couple coats from a paint gun. Stove Brite cans are fine for the DIY'er at home or to keep on hand for touch up. A paint gun will always give you superior results. Stove Brite just doesn't want DIY'ers violating VOC laws, because their product just barely makes the cut for being compliant.
    brenndatomu likes this.
  14. woody5506
    woody5506
    Upstate NY
    Yeah exactly, which is what stove manufacturers do - they aren't spraying them with rattle cans at the factory lol. I was just curious if anyone here had actually done it.
    Jeffrey Svoboda and brenndatomu like this.
  15. Jeffrey Svoboda
    Jeffrey Svoboda
    I'll bet someone has but like many, they don't/won't share their experience.
    If you do end up doing the job and thin the paint, maybe let us know how it went and what ratios you used. Maybe you'll be able to help someone like yourself in the future.
    Highbeam, woody5506 and brenndatomu like this.
  16. woody5506
    woody5506
    Upstate NY
    I've sprayed a lot of indistrial high heat paints, most recommend not to thin but sometimes you have to a bit. Never had an issue. Like someone said if its solvent based it can be thinned. Stove Brite oughta be the same I was just surprised they won't admit it.
    brenndatomu and Jeffrey Svoboda like this.
  17. Highbeam
    Highbeam
    Whatever solvent they use in the cans of stovebrite, phew it's some stinkey stuff. Way harsher than something like rustoleum.
