Jonsered 2258, chain won't stay tight????
Discussion in 'Chainsaws and Power Equipment' started by NYH1, Aug 5, 2025.
  1. NYH1
    NYH1
    Central New York
    My son has a Jonsered 2258, I believe a 2015 production year saw. He took it to our dealer a while back because the chain would become very loose right after tightening it. They replaced the bar, chain (Stihl chain), needle bear and I believe the sprocket.
    It does the same thing. It comes loose pretty much as soon as you start cutting with it. I took the side cover off. Cleaned everything up, put it back together, it came loose as soon as I started gutting? Anyone have any issues with this or a similar saw?
    Thanks, NYH1.
    metalcuttr, John D, RCBS and 2 others like this.
  2. The Wood Wolverine
    Pulling up on the bar before tightening bar nuts, and making them really tight? After tensioning, the nuts are keeping the chain taught so if the bar is slipping, that would be related to tightness. There's no type of lubrication on the studs?
    Can you confirm the rim sprocket is new with a pic?
  3. buzz-saw
    buzz-saw
    Ct.
    Bar stud have an actual shoulder on the bottom that the bar sits on? Could the nuts be bottoming out on the threads of the studs before it fully clamps on the bar?
    Just a thought..............
  4. NYH1
    NYH1
    Central New York
    I'll try to get one later. My grandson (5) is coming over and he loves working on stuff.
    Thanks, NYH1.
  5. NYH1
    NYH1
    Central New York
    We'll have to check that out.
    Thanks, NYH1.
  6. RCBS
    Can we see a pic of the loose chain on the saw (I run mine a bit tight, so 'loose' is subjective)?
    Sometimes if not careful I find that I don't quite get the chain 'seated' in the sprock before tightening down and experience what you are describing. At least I assume that's my folly and why occassionally I will have to retighten just after a chain swap. I usually try to spin the chain a bit before clamping to make sure everything is GTG. Sometimes I must forget. Outboard clutches with rims can sometimes challenge me to get everything in place initially.
  7. John D
    John D
    Syracuse ny
    My 395xp did the same thing
    The tensioner screw was shot replaced because it fell out and problem solved
    metalcuttr, brenndatomu and eatonpcat like this.
  8. The Wood Wolverine
    :yes:
    I too spin the chain every time. I take my scrench and push the backside of a cutter several times somewhat fast. All it took was a couple times of the drivers not in the rim right to change my habits.
  9. Husky Man
    Husky Man
    Mt Hood Oregon
    I had that problem before, when I talked to a logger, he suggested putting a piece of wood under the bar nose so that it is supported when you adjust your chain and tighten the bar nuts, problem solved
    Doug :cheers::usa:
    metalcuttr, tamarack, John D and 2 others like this.
  10. NYH1
    NYH1
    Central New York
    Sorry guys got busy doing a few other things the last couple days. We're getting our pole barn ready for the electricians to run the electrical service Monday morning.
    I'll get a few pic's this weekend. Probably won't be running it this weekend though.
    Thanks, NYH1.
  11. tamarack
    tamarack
    paulina oregon
    I used to have a 272xp that had this issue. Replaced everything to do with the tensioner, and the bar studs. Problem solved.
  12. NYH1
    NYH1
    Central New York
    Thanks for everyone's input so far, I really appreciate it. Been super busy. It's supposed to be like 62° and rain all day tomorrow. So, I'm gonna smoke a couple racks of ribs in the pole barn. I'll mess with saws and stuff while cooking. I'll get some pic's of the sprocket.
    NYH1.
  13. John D
    John D
    Syracuse ny
    You must live around me 60 for a high and rain all day
  14. NYH1
    NYH1
    Central New York
    We're in the Minoa/Bridgeport area. About 15 minutes from Eastwood.
    NYH1.
    John D likes this.
  15. NYH1
    NYH1
    Central New York
    This is after tightening the chain and then running it for two minutes or so.
    These are the best pic's I can get of the sprocket without removing the clutch. It's only been ran a half hour or so since they replaced it.
  16. Husky Man
    Husky Man
    Mt Hood Oregon
    Did you try placing a block of wood under the bar nose to support it, while you adjusted the tension and tightened the bar nuts?
    That made a real difference in my experience
    Doug :cheers::usa:
    theburtman, eatonpcat, John D and 2 others like this.
  17. NYH1
    NYH1
    Central New York
    Yep. As soon as you start to cut, it comes lose.
    NYH1.
    theburtman, Husky Man and John D like this.
  18. John D
    John D
    Syracuse ny
    I live right in Mattydale by the bowling lane use to be called strike and spare
    eatonpcat and NYH1 like this.
  19. John D
    John D
    Syracuse ny
    Sprocket looks great
    If you are running an Oregon chain they will slack up probably 5 times before they are done stretching
    For that reason is why I stopped running them
  20. John D
    John D
    Syracuse ny
    Husky man thanks for the great idea
