Time to revamp my 45ish year old speeco
Discussion in 'Chainsaws and Power Equipment' started by Screwloose, May 1, 2025.
  1. brenndatomu
    7-8 gallons, not as much as I wanted, but it seems adequate, oil temp hasn't went high enough to even check it. (other than by feel)
    eatonpcat, Horkn and Screwloose like this.
  2. brenndatomu
    Now I did change out to a cylinder with larger ports, and all my hoses and fittings got upsized to 3/4", except the one 1/2" fitting coming out of the pump. Was done in the name of cycle time, and lower oil temps...
    Screwloose and Horkn like this.
  3. Canadian border VT
    Screwloose I put my low splitter on grey plastic oil ramps; right size round adda a foot of clearance
    simple easy portable
    RCBS, Screwloose, eatonpcat and 2 others like this.
  4. Screwloose
    My pump and in/out of the valve are 3/4" npt, cyl ports are 1/2" npt on both valve and cylinder. Was thinking about npt to jic but not sure yet.
    Horkn, brenndatomu and eatonpcat like this.
  5. Screwloose
    That is a really good idea, thanks!
  6. brenndatomu
  7. Screwloose
    Haven't had time to mess around with it plus it has been pretty hot out.
    I did get some parts together, valve, motor ,pump, overhung adapter, pulleys and bushings.
